americanhippo
- Mar 4, 2009
Terrace, resale, S$30k...
My Humble Home
Any goot interior ID to recommend?![]()
I only need a carpenter, no ID, any to recommend?
scope of work? kitchen? Wardrobe? budget? schedule?
the carpenters I know, their schedules are pretty tight now. can only start July onwards.
I have limited space for a 4 rm HDB flat.
Would like to make it minimalist and spacious as possible.
Can you help me design concealment bunk bed design?I have limited space for a 4 rm HDB flat.
you can't afford my fees![]()
Advise if not for your personal occupation
don't bother with expensive space-saving furniture etc
Your targeted rough types FW Bunk-Bed Tenants WON'T be able to appreciate
Save your $$ bah - just use the ready-made metal/wooden bunk beds/extra pull-out beds - such CAN go into those older BIGGER bedrooms![]()
I want the HDB flat really spacious and minimalist feeling.![]()
Come out with a bq/quote based on his requirements.
How much you charge for painting? You dont know his housing type, do you?
How much you charge for installing lights and fans?
3 room $1000
4 room $1150
5 room $1300
I really don't use how not knowing his housing type can make a difference.
Installing lightings is $10 per lighting.
Fan is $90
