derkaiser94
- Jan 21, 2012
Just buy on what you think you can afford. Not saying that you have to buy MSI, or have to buy Palit and all. Just choose what you think you are comfortable with, and what you think is worth your pocket value.
For instance imho, i would go for major brands instead over pure "AIB" brand partners. Cause in my personal pov, major brand tends to innovate things/features that i felt useful to a certain extent.
Things like how major brand innovate things.
MSI
They implemented Zero Frozr technology way back in 2002. It was back then where MSI did a zero fan movement when gpu is below a certain temperature. And it was brought back to late 2014-15 with Twin Frozr V cooling technology. And other brands starts to innovate the cooler to work the same like Zero Frozr.
Asus
FanConnect is found in current gen worth of 10-series GTX cards. It is good in every ways to bring in more cooling performance to the GPU. Most of the time when gaming, chassis fan spins at its minimum especially when CPU is not loading. This is the cause of fans connected to mobo CPU fan header or System Fan header. Where it only works in conjunction of CPU temps instead of GPU temps. When gaming, GPU tends to be the hottest, and it is only good that FanConnect is good to conjunction the fans with GPU temps instead.
Gigabyte
They implemented Flex Display technology. This is good for people whom wanna connect multi display. Given the flexibility and ease of using any connections for surround display which.
The only pure "AIB" brand partners that i know that do implement new things is Sapphire with its Vapor Chamber design. There are also other brands out there that does unique, heatsink design and new tech also, but so far the most common ones are major brands that doing all this.
In all, i would pay more a bit to support their research and doings. Which i hope they can continue to improve further in the future.
Pro post! So knowledgeable should do a write up contrasting the different Brands Sia.
. Those using other brand GTX 1080 might want to check this out too.
