Huawei P9 - Change the way you see the world. #OO
skyline72
I just got my P9 Plus (ceramic white) from overseas a few days ago.. will post some user review on P9 Plus.. ^^ all i can say is i'm very impressed by the battery life after using the P9 Plus for 2days..
:eek:
Ceramic white!
How much you got it for ?
moonSymph
P9 Plus Ceramic White User Review
I will let the photo do the talking.. Sorry for the lousy photography skill.. Just some quick snap to share with you guys.. Click on this link to go to the photo album.
P9 Plus and Box..
Accessories are divided into 3 compartment, Charger, Cable, Quick Start Guide + Case
P9 Plus is using a 12V 2A Charger for Huawei QuickCharge. (I tested the same charger work with P9 too which enable Huawei QuickCharge for P9)
Speaker , USB C Port & Earphone Jack.. (Similar to P9)
Sim Card compartment.. love the glossy white ~
The top of the phone is different from P9.. there is an additional infrared in the centre of the bezel.
Power Button & Volume.. Yes the edge of the power button is anodized red.. <3
Another angle!! I absolutely love the button ^^
moonSymph
Dual Cam and Leica wordings..
Front view of P9 Plus
Front view of P9 Plus w/ Lockscreen
Back view of P9 Plus
Size comparison with my P9 Prototype (P9 64GB)
I will be doing a battery test using Antutu battery benchmark.. Both P9 & P9 Plus will be testing in MAX Brightness..
Please check back the thread i will post the result.. =)
johnsonheng
If compare by raw power, one plus three will win, but one plus three get a lot of warranty issue. And the lack of SD card support.
