Huawei P9 - Change the way you see the world. #OO
viberzdae
anyone upgrading from p9 to p9+? And wanna sell ur p9. Im keen to buy..... Please sms whatsapp me 96575700.
Any color, any condition only need 1 set for own use thanks.
caterham7
is there a way to disable HiVoice?
Found if I remove any of it's app permissions, there will be an error message when i click the volume down key by mistake [instead of power button], when the screen is off.
xtramadness
HiVoice is Huawei's answer to Siri or S Voice. You tell a command and your phone will understand it.
However, it seems like there is no way to disable HiVoice message when pressing volume down in lockscreen or to disable HiVoice without rooting and removing it... :(
qyc_91
I'm on 64GB P9 and tbh i didn't notice the HiVoice at all
TitanSmall
is it me or the accessories for P9 quite limited in SG?
really have to get from TB?
anybody wanna whack from TB together to split shipping cosT? :o
Backlash
Just whack the Spigen Rugged Armour and Nano Shield armour SP from TB. The Spigen case is indeed well worth the price at $13 before shipping. As for the Nano Shield SP, similar to invisible shield. Very hard to apply as it is very soft in nature but provide full coverage on the screen including the 2.5D curved edge.
imjoseph
thanks for sharing
