Just installed the new gfx card, however face some problem with display port connection. No problem with DVI.
On first installation, I'm using DVI and loaded into windows to install nvidia driver. After which, I switched to DP and it's fine.
However on the next day when i switch on, the whole power seems to be cut off. No power to mobo but there's light at the GPU. When I tried to remove the DP cable, it suddenly continued to boot into windows, with my bios setting reset.
Any one face similar issue? DP cable seems to be fine since it's ok if i swap it when i'm in windows. Any suggestion on the settings?
My spec :
ASUS H87m-pro
Windows 7
seasonic x650
Thanks in advance
My spec :
ASUS H87m-pro
Windows 7
seasonic x650
Thanks in advance
