Huawei P9 - Change the way you see the world. #OO
cscs3
I tested that my P9 prototype (the 64gb ones) are able to use huawei quickcharge.. when plug in my p9 plus it will say fast charging.. and the charging is really fast just like when i use it on my p9 plus.. but my is the prototype.. i need to test again when i meet my friend so i can use his p9 to test using my p9 plus charger.
P9 64G version os consider as deluxe version right. For some reason. 32g version support only FDD LTE band 1,3,4,7,20. But the deluxe version support FDD LTE 1,2,3,4,5,6,7,8,12,17,18,19,20,26. Basically this is anywhere in the word. Is a very good buy compared to Mi5i if you do not need 2nd sim to support 3G.
Lexyyy
has it been backed up on the previous phone? if yes it'll auto prompt you to restore the backup.
Can, but you may loose the current history on the new phone. :)
Thanks guys! My monochrome contribution taken earlier!!
Sent from HUAWEI VIE-L29 using GAGT
Backlash
This is my contribution to this awesome phone. Taken last Saturday at the NDP Preview 1.
Backlash
Another Question.
I gotten the Invisible Shield type of SP from Taobao. It Covers the entire screen including the 2.5D Curve screen. But the one drawback is that it bubbles up quite easily.
As for tempered glass, it does not cover the entire screen as the SP does not curve.
Therefore a quick question to all the Bros/ Sis here who is currently on the P9. What other SP do u use ?
Do share share . . .
TIA
xtramadness
Another Question.
TIA
Using it nude.... =:p=:p=:p
xtramadness
Seriously ? Nude ? I really hate using the phone nude. No protection.
Haha. Okay lah not really that naked. Using the free cover that came in the box nia. No SP though. Still looking around for the anti-bluelight kind
Backlash
Hoping for a tempered glass that can fit. In the meantime, using my Spigen Rugged Armour with the Nano Shield.
8-lane
hahaha good for you! i'm just checking with xtramadness if he's getting it after the trial
Actually hor.. the P9 phones that u guys (trial users) have on trial.. how much must u all pay if u wanna keep the phone after the trial ends?
