[SIC] Hoot Club! Post Your Technology/Hardware Related Purchases NOW! - Part 3
xokokx
both for 140! :D
can share where u got the mouse pad? thanks:D
tjiax1
anyone can recommend best for buck ssd for laptop. Intend to use on old laptop with windows 10 for school work like programming
Gametaku
Also interested. How is it compres to GT fans? I just ordered 2 x GT 2150 PWM
How's the performance of the ML120 Pro?
Its great! Bought it for push-pull configuration for my graphic card radiator.. the fan ended up cooling my CPU cores instead. Ran 2 hr AIDA64 stability test.. all 4 cores dropped by an average of 2.5c. I believe if you were to use this directly on a CPU heatsink/radiator, the temp would drop more. :s13:
derkaiser94
How's the noise like? Is it very loud? Thinking of getting ether this or the noctua NF-A14 as my front case intake.
Encrypted11
NUC6i5SYH from Amazon July batch, came with bios v42 (voltage regulation issue fix) installed from factory. :D
