Hotels at Pratunam area
dede1217
Hi, anyone here can recommend a hotel for a family of 4 at Pratunam area?
Room for two or a family room is okay~
Thanks!:)
would be good if you can split into two rooms
else can ask hotel if there is connecting room or not ...
kc place have connecting rooms
however location is near airport rajpraprop station, far from platinum mall
can try grand diamond family suite or two bedroom.
price for family suite should be about 160sgd per nite for four ...
convictionn
Thanks!:)
Citadines (affiliate of Ascott/Somerset) have quite a few serviced apartments in the Asok/Nana area which you may consider. Another is Berkeley, opposite Platinum Mall, they also have two bedroom suites at very affordable prices.
amazingone
I see, I have list down some hotels for consideration, don't know is it good or not though:
Arnoma Grand;
GLOW Pratunam; and
Centrepoint Pratunam.
Once considered Grand Diamond too but it looks pretty old though so might not be considering it. :o
Sent from Sumire using GAGT
amazingone
Hmm okay will put in consideration for Citadines and Berkeley, will go around searching for info about it. :)
dede1217
Arnoma Grand;
GLOW Pratunam; and
would choose Centerpoint pratunam ..
Centerpoint pratunam (4ppl and 3ppl) is the same room
with 2 queen bed
just tat 4 ppl they would charge higher :)
location 5min from platinum mall ...
arnoma no family room , superior deluxe juniorsuite ...
hotel location superb, however hotel kinda old, around 16 yrs ...
glow pratunam no family room, deluxe deluxecorner suite
amazingone
with 2 queen bed
I'm fine with two rooms too, so that's why I consider Arnoma(from what I've read from this thread) and GLOW too.
Was considering Centrepoint too but my relative who been there frequently say that it isn't that near to the more popular malls and eateries aren't that much too so might be off the list.
GLOW's room seems quite spacious and room fee per night seems okay too.
joeey
Glow is Not bad... Spacious too
dede1217
glow and centerpoint pratunam is just 10 second walk from each other only.
Glow is about 3 to 5 year younger than centerpoint pratunam ...
glow deluxe is 29m2 , deluxe corner and suite is 42m2 and 43m2
centerpoint family room is about 47m2
not sure if glow pratunam have connecting room, you have to check with them. arnoma would be a better location, beside big c, opp centralworld
dede1217
joeey
Glow dun have connecting rooms, they always gave beside only or maybe i am sway
amazingone
It's fine without connecting room, room side by side is fine too, not so concerned.
Yeah, Arnoma is a good choice too with its superb location but albeit old through read through TripAdvisor reviews say that they are undergoing refurbishing too~
Sent from using GAGT
dede1217
guess their renovation took quite long sia ...
went there in jan this year, they also under renovations ...
their lobby is nice ... newly renovated
but their room is kinda small, despite being 28m2 ...
perhaps their bath room is bigger, hence their sleeping area is small ...
amazingone
Nice to know, will still go and google for more info also haha~
amazingone
Eh between Amari Watergate and Novotel Platinum, which one is a more better choice? Was deciding on GLOW at first but there's only one double room left for my dates I'm at BKK so can't choose it(need two double rooms).. :(
Looking at Novotel's Standard Room and Amari's Deluxe King Room.
