Recommend a Good and Cheap Air-Con Service Company
starlight318
Any experts here to give me some advice on aircon chemical wash? Just did my routine ( every 6 mths) aircon servicing recently and the serviceman told me that i will need to do chemical wash by the next servicing. Said the inside is quite dirty for 2 units ( out of 3) and can only be cleaned by chemical wash.
My question my aircon (inverter panasonic) is only 1.5 years old, no pblms so far just that recently not as cold sometimes. Is it common for aircons to need chemical wash so soon? Or the serviceman trying to chop me? He quoted me $120 per unit by the way.
Thks in advance.
tkl23786
Thks in advance.
Chemical wash should be done at least once a year.
But do be careful of topping up of the refrigerant gas. Topping up of refrigerant is not necessary. But, if there is a leak, you should be finding out the cause of the leak, not topping up the gas.
testerjp
You can do once a year if you don't mind damaging your fins.
I do it at most once every five years.
testerjp
Called this contractor and agreed on $200 for cleaning 4 blowers and when this guy came and after checking he wants $70 xtra cos he say the blower is very dirty wtf in the end have to fork out xtra $70
Cleaning these blowers cost you $270?
This is quite easy to clean.
And i don't see MUCH effect cleaning it because I don't think it's easy to be that dirty. Look at the gaps, it's so ******* big, how can it get clog to deal much effect.
It takes a very long time before dust can accumulate enough until you have to deal with it.
Imagine the dust must go through the two filters
Go through the fins.
Then finally reach the blower.
Want to be super dirty also hard.
I don't even bother cleaning it for a few years.
tatsit
High Honorary Member
anyone got other aircon repair services to recommend? my panasonic aircon not working, outside air temperature sensor failure.
i tried some of the 'recommended' companies here, either no stock or cant do immediately.
gameboy234
My aircon broke down. It was blinking light and not cold.
I ask 2 coy. 1 don't really respond and go mia. The other straight away reply can't help.
Pls provide contact for repair.
woshihuaren
Hi,
one of my aircon unit is not responding to the remote control, the remote is working fine on another unit, thus i suspect it is the sensor issue on the unit (correct me if wrong), i've seen some comments which says the sensor can be repaired/change, but none mentioned how it can be done.
mine is an LG unit (more than 5yrs), can anyone guide how i can DIY to change the sensor (seems to be a 5/10min thing), last resort would be to pay for the servicemen to do it.
much appreciated.
empirestrike
Hi,
much appreciated.
mostly receiver sensor problem... can try manual on the unit....:D:D
woshihuaren
hi, thanks for the advice.
i am currently using manual via unit, it only enables on/off, but not temperature adjustment and the default is always very low/cold (not sure but maybe 16degree...lol), thus need to get the sensor fixed to adjust the temperature.
Goldy740
is this a reasonable quote or are they trying to rip me off
Hi there, we just had an aircon company come around to our flat, i thought we had already arranged for to clean the units but they're just doing a quote.
This is what they have recommended -
servicing 4 units $160
Chemical service 2 outdoor units $300
Top up gas 4 units $80
GST $37.80
Total $577.80
We live in a small 2 bedroom condo with ceiling fans so don't use the aircon very often and it is a brand new condo so they have only been used for 18 months. We have not had them chemically cleaned in that time so maybe we ought to (landlord might be upset if we don't). Not sure why or what the top up gas is for as there are no leaks.
Many thanks
