Using parquet here. I know it scratches but can always polish once a while.
Indeed this industry really full of bad eggs. It seems anyone can be ID and mostly recycle ideasThere are many bad eggs in this industry. Please be careful of this "interior designer" by the name of Eugene Tan. (Mobile 9***3882).
Uses alot of vulgarities and threats of violence. Police report was made against him. He also claimed some lower grade supplier is a partner of the company when it is not (probably to get commission from the supplier). Very unethical and gangster behavior. He jumps around to various different ID firms so I will not state the ID company name.
Ok good to know. I thought he BS me again.Yes esp condos
I've had two places with parquet, never again.
can recommend anyway to remove balcony sliding door and level with living room flooring? for hdb pls. thanks.
Can do. They use some kind of foam padding to raise the floor coz of the floor loading concerns. My parents did this about 15 years ago to their EM. I also came across pics on at renotalk I think...
juz a qns regards to bto... to choose top floor or not? mixed comments leh...![]()
I'm all for choosing highest floor tooHighest* floor best. No restrictions to many stuff, no noisy neighbours above you. Most important is no ugly pipes.
Mixed comments are sour grapes who want the highest floor to themselves and ask the rest to pick the second highest floor.
#justsayinghahahha... I was tinkin tat oso... ppl who sat bad are usually those sour grapes...Highest* floor best. No restrictions to many stuff, no noisy neighbours above you. Most important is no ugly pipes.
lucky I mine is max 12... n I m not a buibui so if really tat suay den go out catch one round pokemon den go back hm lo...I'm all for choosing highest floor too
But my friend who is living in woodlands peak top floor which recently in the news when all the lifts uplorry#justsaying
Sent from LGE LG-H815 using GAGT
ur personal exp?Top floor got problems la... the heat from the sun is really killer on the roof, unless ur unit is below the water tank...
but if ur unit below water tank, u will hear the tank sounds and suffer leakages if the contractor lousy in their workmanship...
never trust that HDB can build the most well insulated and well water proofed building..
top floor means sun shines ur unit from dawn till dust..come home walls hot but if come home late evening or night den not issue lor
some say ceiling paint crack easier but subjective
but everything also got pros n cons.
