M1 FIBRE BROADBAND DISCUSSION
frizee
Hi guys, if I am unable to make it down to Comex, is it ok to sign online? Do I enjoy the same offer as M1 in Comex is giving?
Keen on the $39 offer. :)
frizee
Other than the lucky draw, everything in COMEX is identical to M1's website and/or M1 Shops.
Sent from Sony E5653 using GAGT
I see. Thanks!
As i've got an existing Singtel fiber+mio, I need to terminate.
Any idea how long before I can arrange m1 to come in if i were to terminate ST now?
Called up 3 Singtel CSOs and 3 gave different answers - 3 days / 7 days / 2weeks (business days) :s22::s22:
magix
I see. Thanks!
Others please correct me if I am wrong.
- Suggest to have M1 activate on your PORT 2 Fibre point (your fiber box has two port, Currently Singtel should be using one of them)
- Once M1 installation complete and running. You can arrange to terminate Singtel.
In case activation hit into any issue with M1 and you terminate your ST. you might ended up without internet.
As the others have said, if using wireless only don't go for 1Gbps. From experience the only wireless device I own that can hit anywhere near 1Gbps via wifi on a Asus AC87U is my Macbook Pro which has a rather powerful wireless chip. Phones and tablets will probably get <500Mbps IIRC YMMV.
I'm using old iMac 2.4GHz Core 2 duo.
U can't utilize 1gb using wireless only. The most u get ard 300mbps for mobile device.. And also really depend on how good yr router is. If u dun have wired Lan devices dun go for 1gbps
Mobile wifi use will be mostly whatsapp and minimal internet.
Mostly using on my iMac 2.4GHz core 2 duo.
kandinsky
I see. Thanks!
I think you should be asking M1 side, not ST.
Switched from ST to M1 3 years ago, I can't recall exactly what was done.
This is what I vaguely recall (if I'm not wrong):
Signed up M1 first, then based on when they can start my service, they will advise you when to terminate with ST, then can coordinate so that you have as little downtime as possible.
I think what magix mentioned sounds similar to what was done. Vaguely recall the M1 CSO mentioning something about the 2nd port. So quite likely I signed up and activated M1 first, then terminate ST once it's up and running.
chengsun
I see. Thanks!
If you need to retain your landline number, port over to M1 digital line, you need to unbundle the landline from your fiber, mio 1st.
frizee
Yep, passed by m1 and spoke to the staff. She asked for my postal code (and unit number iirc), then checked and said 'ok, can go ahead to apply'.
But when i asked her 'confirm ah, no conflict or whatsoever?', then she became hesitant liao.
Anyway thanks guys, probably will activate m1 then cancel Singtel. :)
Yep, retained already.
It's an analog line, and confirm can port to m1 so problem
ZrE0_Cha0s
May I ask which conflict do u mean? Cos I'm also would ask u back the question which conflict do u mean? Even I dun understand u mean singtel side or m1 side or other stuff?
crunsik
hihi, i am considering to use M1 for my home connection and would like to check if there are any issues anyone is facing usiing m1? in terms of connection and stuff.
been using ST for a while and their cnnection is bad and intermittent.
FlushX
been with m1 for 20 months. just did my re-contract today for the $39 1gbps plan.
best value for money operator in my opinion.
frizee
Hey hah, what i mean is, cuz im currently on Singtel, and if i were to apply for m1, im afraid the port will be blocked/currently utilized or something (cuz got one telco cso told me about this before, and asked me to ensure that i've cancelled my existing service before changing to a new one)
ZrE0_Cha0s
Don't think iMac of that generation has USB3 yet. Won't get AC speeds.
oh, ya almost forgot that my core2duo laptop also dun have. but still at least he can still get to enjoy some wireless right? even though speed may not be able to reach that high.
ZrE0_Cha0s
well u mean u gonna port over from singtel to m1 for port 1? if this is so u have some downtime without internet.
i still prefer what others have told u to let NLT to activate the 2nd TP port and use it for m1 and later then when m1 is up and running fine, den cancel singtel.
anyway from what he say seems abit weird though its like asking u dun use internet for some time....:s22:
its like he mean that u cancel the services and go sign up for m1, and m1 check with NLT can use your port or not, and they say cant as there is issues and u have to schedule with NLT to solve your port issues b4 m1 can do another schedule with u to come down install their ont for u...by then who knows when u will be able to use your internet =:p
Nikong
Hi guys, i would like to clarify my understanding on the limitation of my PCE-AC68.
The maximum speed that PCE-68AC can support is 1300mbps for 5G and 600mbps for 2.4G so if I top up and purchase RT-AC88U router, even though it can support up to 2167mbps for 5G and 1000mbps for 2.4G, the speed will still be limited by my pci wireless card right?
renfred89
thats right. moreover, maximum speed for both bands will only be achieved if the distance between the router and the adapter is reasonably close with line of sight. you won't be able to achieve maximum speed if lets say its in a room and the router is in the living room.
renfred89
exactly, i second your opinion. If i was in this predicament, i will apply for the new service and terminate the old one if the new service is demonstrating to be working fine.
