Laptop Recommendations for VIDEO
putrasocool
Hi.
I am currently on the lookout for a laptop that is able to do video production.
What i want:
1. Price is not an issue but the cheaper the better.
2. Light weight <2kg. The lighter the better coz i might need to use it everyday in school.
3. 13-14 inch screen only. At least 1080p. Dun need 4k
4. Able to use PREMIER PRO and all ADOBE APPS. I believed most ADOBE apps are GPU accelerated, so;
5. GPU would be better.
6. Long battery life
7. I dun mind MAC or PC as i currently using both.
8. SD slot is a must
what i think suits me:
1. Razer 14 inch
putrasocool
Intrinion
Senior Moderator
Senior Moderator
Will something like an ultrabook works? I really need something light. And i know good packages never comes in handy...
Specifications wise, an ultrabook works.
Just try not to go for the fanless designs as it dissipates heat passively - which over time may reduce the life span of your laptop (due to heat) and possibly thermal throttle (< in performance due to high temps to < heat) - resulting in possible lags.
Do check this video out on 4K video editing on an ultra book, i think it would be of relevance to you :)
putrasocool
I have done a bit of research. Planned to go with mobile workstation like the Dell Precision Series/Lenovo ThinkPad P Series or even the HP ZBook Series. Unfortunately, the price are a bit too high and weighs quite heavy.
Currently, my eyes are on the Lenovo Ideapad 710s PLUS which does have a dedicated GPU, very lightweight and quite new in the market. The package cost around SGD2000
Intrinion
Senior Moderator
Senior Moderator
Don't forget Dell's XPS series as well!
If weight is not a concern then an alternative to workstations could be gaming laptops with dedicated GTX series GPUs such as Aftershocks could work as well.
Had a chance to play around with a Zbook at work for a couple of days .. it was a slab of concrete. :s22: - but one that gives confidence and reliability
putrasocool
Weight is a concern for me unfortunately.
I do notice and quite interested with the XPS line. But the price point is a bit too expensive. Its like paying more for the premium design.
ZBook is the workstation line. So it should be very tough.
I have now widen my choice to:
1. Lenovo IdeaPad 710S Plus - $1800 (AFT Student Disc)
-i7
-Nvidia GT 940MX
-Long battery life
-1.1kg
2. Lenovo ThinkPad P40 Yoga - $2200 (AFT Student Disc)
-i7
-Nvidia Quadro M500M
-8hrs battery
-1.8kg
3. Lenovo ThinkPad T460 (not T460S) - $2200 (AFT Student Disc)
-i7
-Nvidia GT940MX
-Removable battery
-1.7kg
I might seem bias to only Lenovo line. But i have never tried Lenovo products b4. And also i find that the specs that i wanted and and the price point are acceptable compared to other brand.
I have yet to try HP's laptop but I have lost trust in thier products. Prvsly, I used thier printers. Since young it was problematic. We changed to Canon which lasted 5 yrs. 2 yrs ago, we got HP printer back just to give it a try again(who knows they improve?). After months of use, breakdown and replace. Replacement unit also breakdown after months and cannot change. Now, Im using my old Canon which is already 5 yrs old....
