Xiaomi Mi 5s/5s Plus
blurboiboi
Can the dual cam do the bokeh stuffs iPhone 7+ does?
Just picked up my mi5s plus 128gb today. Upgraded from a mi5 64gb.
Love the speed!
The free jelly back case that came with the phone doesn't cover the edges properly. And I can't find anywhere on qoo10 that sells a jelly case that does so.
Anyone can intro any jelly back casing?
Also the tempered glass covers the screen partially only. Anyone bought a good tempered glass for mi5s plus can intro?
Also, in Camera, when the bottom shows "Turn off Stereo" does it mean my dual camera is activated? Or when it has that circular logo?
amazingone
Where can I get Mi5s plus in Hongkong? Need to install playstore myself right?
Hong Kong hasn't start selling the Mi 5s Plus.
However, Taiwan may be releasing it soon with a launch event coming soon, on 7 Nov~
Sent from Sumire using GAGT
kyleongwl
The 1 thing i'm like about the Mi5s+....its processing power
All games are smooth with exception of pokemon go...its GPS/WIFI/Mobile data is weak...(not found when indoor)
The dual camera is fine...(cant tell much difference)
Battery life is well
jackycar
Anyone know where to get the casing for Mi 5S Plus?
OK just to share with everyone.
I used Aliexpress to buy full coverage tempered glass and back jelly clear case for mi5s plus.
Only $1+ USD with FREE shipping. Shiok
jackycar
Battery life. Used it since 12pm today. 930pm at 56% with nearly 3 hrs SOT.
Amazing battery life man. 3800mah and FHD screen.
Used qhd screens for note 4 and note 5 and I can tell u there's NO visible difference from FHD
jackycar
Collecting my plus later from fly house. Kekekeke
Taiwan set coming?...global rom!!! Yaynesssss
Sent from LGE V20 (LG-H990) using GAGT
Actually what advantage for global rom vs China rom and sideboard Play store?
My mi5 I flashed to global rom, but it had less updates than China rom and didn't have crucial features like app search in notification shade
Now using mi5s plus and sideload play store. Seems like best of both worlds
kingsfall
Global rom don't have all those 3rd party china bloatware. But that can be partially solved by uninstalling them
walterteoh
Love the speed!
Hi bro, may I know where you bought the MI5S plus?
Thanks
garychengjw
China Rom
- no google play, must sideload. Google play sync might not works stable.
- quick update.
- some bloatwares.
Global rom
- stable google play, don't need sideload. Sync works perfectly.
- no bloats.
- might not have quickest update like on china.
**If there's dev global rom, the update frequency is around 2 weeks once.
