Is it? Me mute since day 1.....dont even know how it sound...
Expansys is selling the Mi 5s/plus claiming it runs Miui 8 Global ROM 8.010.0.0(MAGCNDH). But I didn't see Miui Forum mentioned that global rom for Mi 5s is available. Is Expansys giving the wrong info?
That sounds like custom. Rom that cannot get updates. Mine is China ROM 8.0.7 MBGCNDH works perfect leh
Nice...me still on 8.0.6Just found out that 8.0.10.0.MAGCNDH is actually a China Stable ROM.
http://en.miui.com/forum.php?mod=viewthread&tid=370651&extra=page=1&mobile=2
Tat a mi5s....not for mi5s plusJust found out that 8.0.10.0.MAGCNDH is actually a China Stable ROM.
just got 5s plus 128gb off lazada. hope it's good and fault free!
middlesky @ lazada selling the 128 mi5s @ $469just got 5s plus 128gb off lazada. hope it's good and fault free!
Has already reported. It's 4+3g.ever since note7 die... i still wonder what phone to buy. Thinking to buy a temporary phone before note8 come.....
should mi5s worth?
the dual sim is 4g/3g or 4g/2g only?
if buy mi5s, from lazada or qoo10?
anyone know any seller are reliable?
used code .'circleslaz' for $30 off
managed to hoot one
Sent from Orion using GAGT
my mimax, redmi note 3 n mi4c can use the dual apps feature on miui 8Hi Bro,
May I know the China Rom 8.0.7 for Mi5S plus got dual apps feature? I knew MiMax got this feature in Rom 8.0.x,. Need to confirm this before order.
Thanks
Walter
The China ROM has three language choices, including:Can check since this is only China ROM, can change the interface to English language? Or stuck with Chinese only?
Also check can the NFC use for Android Pay?
Now debating between this or LG V20... this wins as so much cheaper, but not sure of functionality.
Thanks. That resolves the language.The China ROM has three language choices, including:
Chinese (Simplified),
Chinese (Traditional), and
English.
Android Pay should be able to work, but I'm not too sure of compatibility. Maybe those who have the 5s Plus may want to comment on this.
Sent from Sumire using GAGT
