the ONEPLUS 3
Mclairs83
my camera glass cracked unknowingly. =|
ordered that tiny glass replacement cost me $10+SGD!
hiimajerk
Just got the phone on Monday.
Been noticing that surfing facebook and scrolling down the feed to a certain point and it will force close the app. Reopening the apps to try again yields the same result. Only way to solve is to reboot the whole system. This has been happening two days in a row.
Anyone has a suggestion for a fix?
bastero
Maybe u can try reinstalling the Facebook app or clear the app cache. Ohh can update to the latest oxygenOS 3.2.8. Not sure whether it helps
hiimajerk
I will try reinstalling the app.
Seems like to update to 3.2.8 requires manual input of the patch itself since updating via checking for update states that my phone is up to date. Kinda wanna avoid that for now lol
UPDATE: Reinstalling doesnt work. RIP me lol
bastero
U can use opera vpn app, then change server to canada to get the update via the 'check for updates'. Don't have to tinker much actually.
AsusEpoxy
facebook app drains battery. Try using this app called Metal. i use it to access facebook, much better imo
cweihang
Download Opera VPN. Change location to Canada. And then check for update again! Should detect 3.2.8
Sent from OnePlus ONEPLUS A3003 using GAGT
Pathfinder
My OP3T reached Borderlinx, just activate them to ship out :)
hiimajerk
crapp0
Thx for the tip, it worked like a charm.
Why is it that the update is region specific and not phone model specific?
