Xiaomi TV Discussion Thread II [consolidated]
Chrisxie85
Hi, anyone bought the Xiaomi Tv 3s 65 inch with home theater? I realised my set when connect to ethernet port the 4k stream will stutter and checked that its limited at 100mbit speed. Is the ethernet port on Xiaomi Tv 3s 100mbit or Gbit?
Also anyone experiencing audio cracking at times? Thanks in advance!
gnixer
thinking to create a WA group for this?
or facebook group also can
ckling
My xiaomi 3 is 100mbps...no gigabit
kaitozaki
I would like to share this great app
CETUS PLAY
sideloading apps like those iptv with ads but with adaway apk you will be able to remove ads
Adaway.apk needs root...please root properly...
i1magic
hello , I do not have mitv3s...
as can be see from the pic in this thread, mitv3s 55",60",65"curve,70" are schedule for Jan 2017 updates to the latest "patchwall version"
China users are also not getting the updates...many complaints..
From the same forum, users complains that after updating , mitv3s become less reponsive...
http://www.miui.com/forum.php?mod=viewthread&tid=6479698&highlight=小米电视3s+48寸
http://www.miui.com/search.php?mod=...rchsubmit=yes&kw=小米电视3s&month=&refineSearch=0
This China user has version 1.3.6d (testing version)
http://www.miui.com/forum.php?mod=viewthread&tid=6205095&highlight=小米电视3s
Audio problems caused by software ?
http://www.miui.com/forum.php?mod=viewthread&tid=6166158&extra=&highlight=小米电视3s&page=1
Can always revert back to the previous firmware if the updated firmware is not good.
But you can only go back to the last firmware version.
jinxiang
Hi,
Can i purchase a xiaomi soundbar and connect it to my LG tv?
Can i use the smart tv function in the soundbar?
Thanks.
Don't think you can. It comes with a proprietary connection cable from TV to soundbar. I bought a Xiaomi TV3 60inch for my parents in law last year with subwoofer. I'm more keen to find out if I can buy a pair of surround speakers for that TV.
jinxiang
Yes. I had that cracking sound too. Try unplug and plug the power of surround speakers. That might help.
Do you have problem connecting your HDMI to the TV? I connected TV box / media player thru HDMI to the TV but all contents only show for few seconds and disconnected and go back to home screen. Couldn't figure out the problem yet.
Have you tried upgrading the firmware? Mine is 1.3.3. There is an upgrade available 1.3.4 but tried few times always ended up error and restore back to original.
i1magic
I did a test before, Wifi give better speed over the network cable. So just use Wifi liao.
I can play 4K video @ 60fps via Wifi smoothly on my Mi TV 2 55".
kaitozaki
eh how you know if its 4k play and not downscaled to 1080p...
or is it auto detect?
cause build prop stated...
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=LMY47V
ro.build.display.id=6.12.15.2285
ro.build.version.incremental=2285
ro.build.version.sdk=22
ro.build.version.codename=REL
ro.build.version.all_codenames=REL
ro.build.version.release=5.1.1
ro.build.date=Thu Dec 15 12:42:48 CST 2016
ro.build.date.utc=1481776968
ro.build.type=user
ro.build.user=jenkins
ro.build.host=qh-dk-box-build00
ro.build.tags=release-keys
ro.build.flavor=gladiator-user
ro.product.model=MiTV3-55
ro.product.brand=Xiaomi
ro.product.name=gladiator
ro.product.device=gladiator
ro.product.board=guava
# ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete,
# use ro.product.cpu.abilist instead.
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.manufacturer=Xiaomi
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=monaco
# ro.build.product is obsolete; use ro.product.device
ro.build.product=gladiator
# Do not try to parse description, fingerprint, or thumbprint
ro.build.description=gladiator-user 5.1.1 LMY47V 2285 release-keys
ro.build.fingerprint=Xiaomi/gladiator/gladiator:5.1.1/LMY47V/2285:user/release-keys
ro.build.characteristics=tv
# end build properties
# from device/mstar/gladiator/system.prop
#bootloader environment variables
#bootenv.var.bootsystem=
#bootenv.var.factorytest=
bootenv.var.mi-Factory=
bootenv.var.factory_power_mode=
bootenv.var.eth_macaddr=
bootenv.var.serialno=
bootenv.var.bt_mac=
bootenv.var.wifi_mac=
bootenv.var.updatestat=
bootenv.var.mn=
bootenv.var.resolution=
bootenv.var.resolution_reset=
bootenv.var.panel_path=
bootenv.var.db_table=
bootenv.var.reproducerate1080=
bootenv.var.reproducerate720=
bootenv.var.reproducerate576=
bootenv.var.reproducerate480=
bootenv.var.dc_poweroff=
bootenv.var.51OnRam=
bootenv.var.str_crc=
bootenv.var.info_exchange=
bootenv.var.upgrade_mode=
bootenv.var.logo=
bootenv.var.music=
bootenv.var.music_vol=
bootenv.var.CbkOffset=
bootenv.var.partitions_err=
bootenv.var.tp_product=
bootenv.var.tp_vendor=
bootenv.var.bootlogo_gopidx=
bootenv.var.rtpm=
bootenv.var.delta_time=
bootenv.var.product_region=
bootenv.var.music_control=
bootenv.var.secureinfo_correct=
bootenv.var.console_disable=
persist.service.bdroid.battery=100
persist.service.bdroid.ble=0
timedtext.use.source=ffmpeg
persist.sys.power.press.2.susp=0
# ADDITIONAL_BUILD_PROPERTIES
persist.sys.language=zh
persist.sys.country=CN
persist.sys.timezone=Asia/Shanghai
wifi.interface=wlan0
ro.opengles.version=196608
ro.sf.lcd_density=320
media.aac_51_output_enabled=true
config.disable_bluetooth=0
chrome.tv.hole_threshold=0
debug.hwui.render_dirty_regions=false
service.adb.tcp.port=5555
persist.adb.tcp.port=5555
persist.service.adb.enable=1
ro.adb.secure=1
mstar.build.mstartv=sn
ro.mstar.lmkd.minfree=8419,10563,12708,14932,25764,37047
ro.mstar.lmkd.adj=0,58,117,176,529,882
mstar.framebuffer.format=3
mstar.gop=0
mstar.gwin=0
mstar.gopfrc=2
mstar.dest-hwcursor-gop=3
mstar.forcelandscape=0
mstar.mali.alloc.strategy=true
mstar.maliion.dismem.location=0
mstar.maliion.default.location=discrete
mstar.hwcGOP=3
mstar.4k2k.2k1k.coexist=true
mstar.switch.timing.enable=false
mstar.str.enable=true
mstar.lvds-off=0
mstar.desk-display-mode=0
mstar.pdp-xoffset=0
mstar.pmem.poolsize=33554432
dfb_jpd_write_buffer=SkiaDecodeMutex
mstar.mstplayer.bd=0
mstar.meta.sf=0
mstar.videoadvert.finished=0
mstar.mediascanner_onlysd=1
mstar.resmgr_v4.enable=1
bluetooth.sco_over_btmic=1
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.heapsize=256m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=512k
dalvik.vm.heapmaxfree=8m
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
persist.sys.dalvik.vm.lib.2=libart.so
dalvik.vm.isa.arm.features=div
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
anyone want to try edit to make it better???
this one from mibox international...the one with netflix and google play ect...
ro.build.id=MHC19J
ro.build.display.id=once-userdebug 6.0.1 MHC19J 204
ro.build.version.incremental=204
ro.build.version.sdk=23
ro.build.version.preview_sdk=0
ro.build.version.release=6.0.1
ro.build.version.security_patch=2016-05-01
ro.build.version.base_os=
ro.build.date=Thu May 26 09:52:02 CST 2016
ro.build.date.utc=1464227522
ro.build.type=userdebug
ro.build.host=qh-dk-box-bsp01
ro.build.flavor=once-userdebug
ro.product.model=MIBOX3
ro.product.name=once
ro.product.device=once
ro.product.board=once
ro.product.locale=en-US
ro.wifi.channels=14
ro.board.platform=gxl
ro.build.product=once
ro.build.description=once-userdebug 6.0.1 MHC19J 204 release-keys
ro.build.fingerprint=Xiaomi/once/once:6.0.1/MHC19J/204:userdebug/release-keys
ro.build.characteristics=mbx,nosdcard
# from device/xiaomi/once/system.prop
# Set display related config
ro.platform.has.mbxuimode=true
ro.platform.has.realoutputmode=true
ro.platform.keepbackground.app=com.droidlogic.PPPoE
#camera max to 720p
ro.camera.preview.MaxSize=1280x720
ro.camera.preview.LimitedRate=1280x720x30,640x480x30,320x240x28
ro.camera.preview.UseMJPEG=1
#if wifi Only
ro.radio.noril=false
#if need pppoe
ro.net.pppoe=true
#the prop is used for enable or disable
#DD+/DD force output when HDMI EDID is not supported
#by default,the force output mode is enabled.
#Note,please do not set the prop to true by default
#only for netflix,just disable the feature.so set the prop to true
ro.platform.disable.audiorawout=true
#Dolby DD+ decoder option
#this prop to for videoplayer display the DD+/DD icon when playback
ro.platform.support.dolby=true
#DTS decoder option
#display dts icon when playback
ro.platform.support.dts=true
#DTS-HD support prop
#ro.platform.support.dtstrans=true
#ro.platform.support.dtsmulasset=true
#DTS-HD prop end
# Enable player buildin
media.amplayer.seekkeyframe=true
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=ac3,eac3,rm,dts
media.amplayer.enable=true
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
media.amplayer.thumbnail=true
media.amplayer.widevineenable=true
media.amplayer.dsource4local=1
media.amplayer.startmode=true
media.amplayer.dropwaitxms=100
media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm
media.wfd.use-pcm-audio=false
media.wfd.videoresolution-type=1
media.wfd.videoresolution-group=0
media.wfd.videoframerate=24
media.wfd.video-bitrate=2000000
media.html5videowin.enable=1
media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo
media.decoder.vfm.drmmap=decoder amvideo
#add for video boot, 1 means use video boot, others not .
service.bootvideo=0
# Define drm for this device
drm.service.enabled=1
#used forward seek for libplayer
media.libplayer.seek.fwdsearch=1
#fix hls sync
libplayer.livets.softdemux=1
libplayer.netts.recalcpts=1
#map volume
ro.audio.mapvalue=0,0,0,0
#By default, primary storage is physical
#ro.vold.primary_physical=true
#Support storage visible to apps
persist.fw.force_adoptable=true
#add livhls,libcurl as default hls
media.libplayer.curlenable=true
media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod
#Hdmi In
ro.sys.hdmiin.enable=false
mbx.hdmiin.switchfull=false
mbx.hdmiin.videolayer=false
dalvik.vm.heapstartsize=16m
dalvik.vm.heapgrowthlimit=256m
dalvik.vm.heapsize=512m
ro.config.wallpaper=/system/etc/default_wallpaper.png
persist.sys.media.avsync=true
sys.fb.bits=32
ro.hdmi.device_type=4
persist.sys.hdmi.keep_awake=false
ro.carrier=wifi-only
config.disable_bluetooth=false
sys.display-size=3840x2160
ro.opengles.version=131072
camera.disable_zsl_mode=1
ro.app.optimization=false
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=6.0_r1
ro.nrdp.modelgroup=XIAOMIM12TRIAL
drm.service.enable=true
dalvik.vm.isa.arm.variant=cortex-a9
dalvik.vm.isa.arm.features=default
dalvik.vm.lockprof.threshold=500
net.bt.name=Android
ro.expect.recovery_id=0x1f6d7af2b03dcb241337202753a7b76e068fb2c0000000000000000000000000
don't know why must have ringtone...
or anyone want to try do boot animation...short and sweet boot animation would be nice...with 4k...i think the one inside the system could be 1080p...
