Overall Nougat brings a lot more to the table than Marshmallow... battery life will be better, it's more compact, updates are faster, and it runs faster still...
Runs faster? I'm quite sure it is placebo effects here. Maybe small millisecond differences plus and minus. The device is already very fast and snappy even on Android 6. Unless the file system changes to a faster reading and writing one, the difference should be negligible.anyone having issue with 5Ghz WiFi? it's the only device on my network that can't stay connected
Sent from Huawei NEXUS 6P using GAGT
Updates are faster, we have to see how fast Samsung can put them out.Runs faster? I'm quite sure it is placebo effects here. Maybe small millisecond differences plus and minus. The device is already very fast and snappy even on Android 6. Unless the file system changes to a faster reading and writing one, the difference should be negligible.
Sorry off topic.
Just want to ask if u are related to Teo En Ming?![]()
Anybody hv this issue wif their s7/s7e ?
When taking a long video under 1080/30fps on the stock cam, intermittenly after u paused and/or resume later when playback the video will be jerky or stuttered.. I've already updated to the latest fw and even hard reset it.. but prob still persist... anyone got encounter same thing before ?
I doubt camera faulty as I notice only after I pause and resume (intemittently) then got such problem, not at the beginning of every video.. The thing is, when I was taking the video all is fine on the screen.. so I cant tell when the video will start to jerk or stutter when I pause and resume multiple times..
yeah, I know I can just video w/o pausing and resume but sumtimes u just need to pause recording for a short while and then cont wif your long video taking... eg. family picnic outing, swimming etc..
is this some kind of bug ? Those bros testing the Nougat, can look into this too ?
I tested out in 1080/30fps and even 4k video, there is a problem like what you described..
Perhaps your memory card not fast enough?
Ahhh... heng I'm not the only one experiencing this..
I record direct to internal memory, not sd card...![]()
Sorry I just edited. There ISN'T an issue with me. I tried to record 15s just for testing sake, many pauses in between and is recorded to SD card directly. No hiccup at all except for the random pause due to the cut in video recording..
I think you haven't read... instead of downloading the entire apk to update apps, only the bits that needs updating will take place... firmware updates won't be have the phone shut down for 30 min or so for everything to be updated... that's pretty significant... especially when you get security updates...
Don't worryseems like Jan firmware update is ann important security patch, advisable for all to update.
https://www.xda-developers.com/andr...-january-2017-released-for-supported-devices/
Anybody hv this issue wif the s7/s7e ?
Tiagong is coming to Singapore...
