Xiaomi TV Discussion Thread II [consolidated]
limyeewee
Need some advice. I am using Mi TV 2S with YouTube, but the video playback for 720 and 1080 video is stuttering. May I know how this can be resolve?
Mi TV 2S firmware - 1.2.15
YouTube for Android TV - 1.3.11
kaitozaki
you can't by default it was working on the older firmware, after update they change "hardware acceleration" instead of "software acceleration"
on my mitv2 55 firmware 1.3.8 is fixed...but if playing long video it will hang abit...i'm guessing they never use to auto switch mode...
we had this problem before...i don't think the app is the problem as i tried all youtube for android tv versions...
the fix...update firmware...for now...unless someone else has a fix by editing build.prop
i1magic
Can you try and play the same YouTube video on Kodi?
i1magic
eh how you know if its 4k play and not downscaled to 1080p...
or is it auto detect?
cause build prop stated...
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=LMY47V
ro.build.display.id=6.12.15.2285
ro.build.version.incremental=2285
ro.build.version.sdk=22
ro.build.version.codename=REL
ro.build.version.all_codenames=REL
ro.build.version.release=5.1.1
ro.build.date=Thu Dec 15 12:42:48 CST 2016
ro.build.date.utc=1481776968
ro.build.type=user
ro.build.user=jenkins
ro.build.host=qh-dk-box-build00
ro.build.tags=release-keys
ro.build.flavor=gladiator-user
ro.product.model=MiTV3-55
ro.product.brand=Xiaomi
ro.product.name=gladiator
ro.product.device=gladiator
ro.product.board=guava
# ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete,
# use ro.product.cpu.abilist instead.
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.manufacturer=Xiaomi
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=monaco
# ro.build.product is obsolete; use ro.product.device
ro.build.product=gladiator
# Do not try to parse description, fingerprint, or thumbprint
ro.build.description=gladiator-user 5.1.1 LMY47V 2285 release-keys
ro.build.fingerprint=Xiaomi/gladiator/gladiator:5.1.1/LMY47V/2285:user/release-keys
ro.build.characteristics=tv
# end build properties
# from device/mstar/gladiator/system.prop
#bootloader environment variables
#bootenv.var.bootsystem=
#bootenv.var.factorytest=
bootenv.var.mi-Factory=
bootenv.var.factory_power_mode=
bootenv.var.eth_macaddr=
bootenv.var.serialno=
bootenv.var.bt_mac=
bootenv.var.wifi_mac=
bootenv.var.updatestat=
bootenv.var.mn=
bootenv.var.resolution=
bootenv.var.resolution_reset=
bootenv.var.panel_path=
bootenv.var.db_table=
bootenv.var.reproducerate1080=
bootenv.var.reproducerate720=
bootenv.var.reproducerate576=
bootenv.var.reproducerate480=
bootenv.var.dc_poweroff=
bootenv.var.51OnRam=
bootenv.var.str_crc=
bootenv.var.info_exchange=
bootenv.var.upgrade_mode=
bootenv.var.logo=
bootenv.var.music=
bootenv.var.music_vol=
bootenv.var.CbkOffset=
bootenv.var.partitions_err=
bootenv.var.tp_product=
bootenv.var.tp_vendor=
bootenv.var.bootlogo_gopidx=
bootenv.var.rtpm=
bootenv.var.delta_time=
bootenv.var.product_region=
bootenv.var.music_control=
bootenv.var.secureinfo_correct=
bootenv.var.console_disable=
persist.service.bdroid.battery=100
persist.service.bdroid.ble=0
timedtext.use.source=ffmpeg
persist.sys.power.press.2.susp=0
# ADDITIONAL_BUILD_PROPERTIES
persist.sys.language=zh
persist.sys.country=CN
persist.sys.timezone=Asia/Shanghai
wifi.interface=wlan0
ro.opengles.version=196608
ro.sf.lcd_density=320
media.aac_51_output_enabled=true
config.disable_bluetooth=0
chrome.tv.hole_threshold=0
debug.hwui.render_dirty_regions=false
service.adb.tcp.port=5555
persist.adb.tcp.port=5555
persist.service.adb.enable=1
ro.adb.secure=1
mstar.build.mstartv=sn
ro.mstar.lmkd.minfree=8419,10563,12708,14932,25764,37047
ro.mstar.lmkd.adj=0,58,117,176,529,882
mstar.framebuffer.format=3
mstar.gop=0
mstar.gwin=0
mstar.gopfrc=2
mstar.dest-hwcursor-gop=3
mstar.forcelandscape=0
mstar.mali.alloc.strategy=true
mstar.maliion.dismem.location=0
mstar.maliion.default.location=discrete
mstar.hwcGOP=3
mstar.4k2k.2k1k.coexist=true
mstar.switch.timing.enable=false
mstar.str.enable=true
mstar.lvds-off=0
mstar.desk-display-mode=0
mstar.pdp-xoffset=0
mstar.pmem.poolsize=33554432
dfb_jpd_write_buffer=SkiaDecodeMutex
mstar.mstplayer.bd=0
mstar.meta.sf=0
mstar.videoadvert.finished=0
mstar.mediascanner_onlysd=1
mstar.resmgr_v4.enable=1
bluetooth.sco_over_btmic=1
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.heapsize=256m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=512k
dalvik.vm.heapmaxfree=8m
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
persist.sys.dalvik.vm.lib.2=libart.so
dalvik.vm.isa.arm.features=div
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
anyone want to try edit to make it better???
this one from mibox international...the one with netflix and google play ect...
ro.build.id=MHC19J
ro.build.display.id=once-userdebug 6.0.1 MHC19J 204
ro.build.version.incremental=204
ro.build.version.sdk=23
ro.build.version.preview_sdk=0
ro.build.version.release=6.0.1
ro.build.version.security_patch=2016-05-01
ro.build.version.base_os=
ro.build.date=Thu May 26 09:52:02 CST 2016
ro.build.date.utc=1464227522
ro.build.type=userdebug
ro.build.host=qh-dk-box-bsp01
ro.build.flavor=once-userdebug
ro.product.model=MIBOX3
ro.product.name=once
ro.product.device=once
ro.product.board=once
ro.product.locale=en-US
ro.wifi.channels=14
ro.board.platform=gxl
ro.build.product=once
ro.build.description=once-userdebug 6.0.1 MHC19J 204 release-keys
ro.build.fingerprint=Xiaomi/once/once:6.0.1/MHC19J/204:userdebug/release-keys
ro.build.characteristics=mbx,nosdcard
# from device/xiaomi/once/system.prop
# Set display related config
ro.platform.has.mbxuimode=true
ro.platform.has.realoutputmode=true
ro.platform.keepbackground.app=com.droidlogic.PPPoE
#camera max to 720p
ro.camera.preview.MaxSize=1280x720
ro.camera.preview.LimitedRate=1280x720x30,640x480x30,320x240x28
ro.camera.preview.UseMJPEG=1
#if wifi Only
ro.radio.noril=false
#if need pppoe
ro.net.pppoe=true
#the prop is used for enable or disable
#DD+/DD force output when HDMI EDID is not supported
#by default,the force output mode is enabled.
#Note,please do not set the prop to true by default
#only for netflix,just disable the feature.so set the prop to true
ro.platform.disable.audiorawout=true
#Dolby DD+ decoder option
#this prop to for videoplayer display the DD+/DD icon when playback
ro.platform.support.dolby=true
#DTS decoder option
#display dts icon when playback
ro.platform.support.dts=true
#DTS-HD support prop
#ro.platform.support.dtstrans=true
#ro.platform.support.dtsmulasset=true
#DTS-HD prop end
# Enable player buildin
media.amplayer.seekkeyframe=true
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=ac3,eac3,rm,dts
media.amplayer.enable=true
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
media.amplayer.thumbnail=true
media.amplayer.widevineenable=true
media.amplayer.dsource4local=1
media.amplayer.startmode=true
media.amplayer.dropwaitxms=100
media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm
media.wfd.use-pcm-audio=false
media.wfd.videoresolution-type=1
media.wfd.videoresolution-group=0
media.wfd.videoframerate=24
media.wfd.video-bitrate=2000000
media.html5videowin.enable=1
media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo
media.decoder.vfm.drmmap=decoder amvideo
#add for video boot, 1 means use video boot, others not .
service.bootvideo=0
# Define drm for this device
drm.service.enabled=1
#used forward seek for libplayer
media.libplayer.seek.fwdsearch=1
#fix hls sync
libplayer.livets.softdemux=1
libplayer.netts.recalcpts=1
#map volume
ro.audio.mapvalue=0,0,0,0
#By default, primary storage is physical
#ro.vold.primary_physical=true
#Support storage visible to apps
persist.fw.force_adoptable=true
#add livhls,libcurl as default hls
media.libplayer.curlenable=true
media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod
#Hdmi In
ro.sys.hdmiin.enable=false
mbx.hdmiin.switchfull=false
mbx.hdmiin.videolayer=false
dalvik.vm.heapstartsize=16m
dalvik.vm.heapgrowthlimit=256m
dalvik.vm.heapsize=512m
ro.config.wallpaper=/system/etc/default_wallpaper.png
persist.sys.media.avsync=true
sys.fb.bits=32
ro.hdmi.device_type=4
persist.sys.hdmi.keep_awake=false
ro.carrier=wifi-only
config.disable_bluetooth=false
sys.display-size=3840x2160
ro.opengles.version=131072
camera.disable_zsl_mode=1
ro.app.optimization=false
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=6.0_r1
ro.nrdp.modelgroup=XIAOMIM12TRIAL
drm.service.enable=true
dalvik.vm.isa.arm.variant=cortex-a9
dalvik.vm.isa.arm.features=default
dalvik.vm.lockprof.threshold=500
net.bt.name=Android
ro.expect.recovery_id=0x1f6d7af2b03dcb241337202753a7b76e068fb2c0000000000000000000000000
don't know why must have ringtone...
or anyone want to try do boot animation...short and sweet boot animation would be nice...with 4k...i think the one inside the system could be 1080p...
Can see that the video is much sharper. The only question is whether is it really 60fps.
So what can we do with all this build.prop?
limyeewee
I just tried on Kodi. No stuttering on 720 on Kodi YouTube, but stuttering on YouTube. Can't try anything above 720 because Kodi YouTube can't go above.
i1magic
Ok. Try to update to the latest firmware and try again.
This problem should be due to the firmware.
kaitozaki
edit...edit...edit...
as for google play, from first boot it will try to detect device, what i found online is that they spoof device to nexus 7 or shield tv box...others use android tv (sony or LG i think) but not sure if it would wont...this month i would be busy so by next month i would give it a try...if others would like to try becareful and try to make a backup...even rooting... =:p
i1magic
Think this need to be done by people who are experienced. For people who dare not experienced, shouldn't try this at all.
Soyeon
I brought a pair of speaker with Karaoke Mic, with Bluetooth connection too.
no matter how i try, xiaomi tv 3 would't let me play sound from my new speakers.
i even tried bluetooth connect to my speakers also cannot.
Tried using RCA to connect also no sound.
Xiaomi TV 3 55 Inch, Original Chinese Version, Never Root Before.
i1magic
Mi TV 3 should be the ones that everything is on the soundbar, then from soundbar a cable connects from the Mi Port to the TV's Mi Port, correct?
i1magic
alferseet
My Mi Tv3s 60 inch was rooted with Kingroot successfully and google stuff installed nicely. However, the Tv became less responsive after watching for a while.
I then decided to remove the google stuff and kingroot.
However, i was stupid enough to think that i should use Appmover to move all the google including a system app called "Android" (yes its listed in english and therefore thought it was one of those google stuff i installed)
back to normal app before unrooting. Halfway through moving the apps from system back to normal with system app mover, a reboot was necessary and when it rebooted to the bluescreen only to auto shut off the whole TV and soundbar(no light at all)
Powering on and on again produces the same result.
I manage to get into recovery mode by pressing and holding the volume up and down button on the soundbar and then a quick press on the power on button.I cleared all data and cache and reboot into system 2( Which i had never booted in before) and after showing the blue screen with a progress bar and a translated liner "A new experience coming your way" it shows a black screen with huge text saying "FACTORY TEST MODE" and nothing happens after that.
I tried again to boot into System 1 but it auto shut off after the blue screen.
Anyone got any idea what can i do?
