Endowment/saving plan vs RSP in Bank
vincent007
Recently offered by an agent for a 15yr saving plan (PruFlexiCash) and after some research it looks like I'd be better with investing in Bank, say POSB Invest Saver.
I am comparing the last 5 yrs return of Prudential vs Nikko AM Singapore STI ETF, which is 3.98% (until 2015) vs 4.03% (until 2017).
Looking at it, the returns are quite similar. However, if looking at the cost, Prudential distribution cost is $8,115 out of $90,916 premium paid in 15 yrs, which is abt 8.9%.
Meanwhile, POSB invest saver only has 0.5% (or 1% for ETF) transaction fee.
Is my comparison correct or do I miss something?
Plus the flexibility of withdrawal 100% of the invested amount in POSB Invest Saver. It looks like a no brainer for me just to go with this instead of the endowment plan (not only Prudential, basically any endowment plans out there).
anfielder
Meanwhile, POST invest saver only has 0.5 transaction fee.
Plus the flexibility of withdrawal 100% of the invested amount in POST Invest Saver. It looks like a no brainer for me just to go with this instead of the endowment plan (not only Prudential, basically any endowment plans out there).
Returns to the policyholder are much lower than that of the par fund. Look at the benefit illustration, and you'll see that the returns are in the region of 2-3%.
Your agent will tell you it's higher than FD, but wouldn't you want better returns for locking away your money for 15 years?
vincent007
you can sic the BI of the pruxi flex plan here
Total premium: $90,916
Guaranteed: $69,000
Total Non-guaranteed: $100,006 (3.25%) or $110,185 (4.75%)
Lower because of distribution cost?
anfielder
Guaranteed: $69,000
Plug that into a financial calculator, and it works out to 1.18% (for 3.25% on par fund) or 2.37% (for 4.75% on par fund).
That's part of it. Also, not all your premium goes to par fund e.g. the insurance cover and any riders. And part of the par fund returns can be given to the insurance company's shareholders.
vincent007
Thanks for this!
guaranteed so low???
ditch the plan ba
:s13: yea, just signed still can cancel. There's option to withdraw 2nd year onwards, that's why it's low?
akwl88
Thanks for this!
cashback option issit?
the more complicated a plan is, the more it will only benefit the sellers
you, as a buyer, stand to lose out a lot
akwl88
cashback option is a stupid thing
tell pple to save for future then offer cashback
dumb move
akwl88
RSP = investment
if save money = high yield bank acct/ssb/fd
take note of liquidity if u want high or low
Mecisteus
If you have $500 to save monthly, you can consider splitting some into Singapore Saving Bonds or overseas ETFs. This method requires a little bit discipline and manual executions on your part unlike buying STI ETF through POSB Invest Saver.
mSnooze
Thanks for this!
I can show you plans with cashback and guaranteed portion higher than your total premiums paid easily. There are a few of those out there.
Nevertheless, you can get a copy of Shiny things ebook or read around the forum before you get anything. Many things you can do with money to grow money.
Sent from Samsung SM-G935F using GAGT
Shion
Senior Mentor
If you get PruFlexiCash Protection Plus, it has a high death benefit (4x of your sum assured). Furthermore it is not capital guaranteed.
