[IOS/Android] War Of Crown
MYcheesecake
Thanks for your kind advice.
Btw, as for my 5* dark arin and new 4* light arin, should i feed the dark one to light arin instead and regrind the light arin
koicafex
:s13: jian
it is possible to play tank team and down them
just that u get 2* for going past 11th turn nia
light aren + light kalito allows u to survive earthquake
Jian19
For wad drag so long when u can burst them down :s22: unless u dun have any mage then LLST go for tank and DPS
IStayInHougangChalet
my team now is
DPS: dark nazdan, light garred
RANGE: dark + light kalias << thinking of taking light kalias out, replaced by either treant or fairy. tank vs support which 1 shld i pick?
cannot clear 1st map of mystic.
what else can i do ar?
edit: found this guide. not bad
https://mobilegamerhub.com/war-of-crown/general-leveling-tutorial-for-newbies/
2 Melee DPS, 1 Ranged DPS, 1 Support -> works great for faster runs. Unless your team gets annihilated easily, this is the best for auto, especially if you have Nazdan.
so i guess i will go for fairies? or just use the free light arin sua? :s13:
koicafex
u need speed accessories on your light arendel so he start first
or u give hp item to your mages so they survive the initial hit
then its ez alr
Jian19
U need Ardenel for Mystic , go clear story mode to get it free
Jian19
Ah yea....Finally max out my Zilean and got my first 6* accessories
lup abit garnets to refill energy. lvl 18 liao
who else on US?
edit: and i got my free arendel :love:
going to pump ah pump arendel
Jian19
Think they patch the game, now if u kill the 3* lycan u have to kill the minions as well
Ok i just kill another 3* lycan and immediately the round is over. Wtf ? :s22:
Elunee
Hi everyone,
I just recently started WoC, it's been 2 days since I started.
I managed to roll the following heros:
1) Dark Nazdan Lvl 35 5*
2) Light Edgar Lvl 30 5*
3) Dark Kalias Lvl 35 5*, Water Kalias Lvl 20+ 5*
4) Water Eldin Lvl 33 5*
I would love to have some advice from the veteran players (eg. koicafe7 zehzeh, Jian19) here as I'll like to clear the Zidean dungeon before the event ends on 18th May.
I'm currently stuck on the 2nd stage of Zidean dungeon and unable to progress anymore, they hit like a truck to my team.
I'm thinking of using Dark Fairy (Nat 3*) and Arden (4* Light Tank) but unsure whom to swap out.
Please help advise, hahaha, thanks! :)
koicafex
evolve ur team...
farm mythic map for 2* boss that drops 5* accessories
