Xiaomi Mi Max 2 - The new BIG gets even better!
kelvinti
After NSE cancelled my mi mix order last year, a bit wary to buy from them. Guess simder then
Haha. Understood, bro. Some more, this is an pre order, just likes the Mi MIX from them that screwed us big time. Lol..
pokipoki08
https://www.gizmochina.com/2017/06/06/xiaomi-mi-max-2-vs-xiaomi-mi-6-camera-comparison-sensor-ensure-similar-camera-performance/
but low light & lack of OIS leaves Mi Max 2 struggling
davidwong
This is slight off topic but today QOO10 has Korea S7 refurbish SGrade (whatever that means) also 600, which one i should grab as I gotten the 100 voucher too but I alas bought my redmi note 4 (4/64) already from Lazada
minamikaze
hooting the mi max 2 at $330 too. too good of a deal to pass up, and I loved the original mi max.
kelvinti
S7 is surely better than Mi Max 2 amid the small 5" screen! S7 has awesome camera too!
So, it depends on what is your priority!
Solid camera with a small 5" screen or not-solid camera with a huge 6.4" screen.
YOu have got to make a decision on your own!
if battery is a priority, definitely mi Max 2. plus it is full HD.
Lss
Tks bro. Straight away HOOTED :s12:
BTW, I can buy screen protector/backcase for MiMax1... should fit right?
Ya lor I want to know too. Need to get a flip case and screen protector.
vhungryy
In this thread, it's go BIG or go home! Hahah.
$330.... Wonder will this deal come by again...
minamikaze
Tks. Anyone with recco for MM2 accessories, post link here... TIA
I checked online and the difference is like 1mm or less...
Mi Max
Dimensions: 173.1 x 88.3 x 7.5 mm
Mi Max 2
Dimensions 174.1 x 88.7 x 7.6 mm
So there is a chance that those silicone type casings might fit.. but perhaps not the rigid types.
amazingone
Mi Max
Mi Max 2
You also have to note that the fingerprint sensor and camera cutout might be different too, and the IR sensor is also located on the center of the top for the Mi Max 2.
Sent from an Xperia using GAGT
pokipoki08
Pics of different silicone covers with enhanced corner protection, the last one is less bulky
Silicone is important to absorb and transfer impact away from phone body & display.
Which one seems to be the thickest at the corners? Hard to evaluate from pics alone.
