devileagleclaws
- Jun 27, 2012
Hi all,
Would like to get some guides or solution from you guys.
I signed up Singtel Fibre, which is 1Gbps and it came with the AZTECH 2400 router. The router is placed at my living room, and i tested the speed on AZTECH router using wired connection is about 900Mbps.
ONT > AZTECH > Laptop
So I tried to set up my ASUS RT AC55UHP at my living room to replace the AZTECH router, but the speed with the ASUS router became about 300Mbps.
ONT > ASUS > Laptop
I find it weird that one wired connection, ASUS router only can hit 300Mbps, so I configured it to AP mode to see the speed and it can go up to 900 Mbps.
ONT > AZTECH > ASUS > Laptop.
I had a TP-Link in my room which is connected to the AZTECH router, speed test at 600Mbps.
ONT > AZTECH > TP-Link > Laptop
So because I tried all means on my ASUS router, and cant get up to the given speed, and decide to replace my TP-Link to ASUS router. After replacing the router, I do a speed test. It can go up to 900Mbps, then I do the speed test again, it drops to 90Mbps. Then I changed back to TP-Link, first test at 900Mbps, second test 90Mbps.
Singtel had just changed my ONT and updated the firmware of the AZTECH router few days ago.
Any one can help me?
Actually I just want my ASUS RT AC55UHP to replace the AZTECH router with the max speed I signed up for (800Mbps to 1Gbps)
Sorry for the long story,
Hope some one over here can help with me. Thanks.
ONT > ASUS > Laptop
