Air conditioning - Any recommendations please??
kael1n83
get 5 ticks. i've been on mitsubishi for abt a year leow. and yes, 2 ticks are to clear stock.
instead of the standard bundle, request for the "best" compressor. for example sys4 compressor change to sys5
for 4 units, if space for compressor is not an issue, do you recommend:
1) sys3 + separate unit for living or
2) sys4 (and changing compressor to sys5)?
nakitaro
2. imagine running two pc but you cld hv run a second one using vm. which is more energy efficient? something like that.
Kino Onik
Hi gurus
I'm seeking your opinions on installation of aircons. Currently undergoing reno for my hdb resale 4 room flat. MBR will use 8 hours daily and living room 3-4 times weekly. 2 spare rooms will be used occasionally as guests room. Kindly advice on recommended aircons. I've a quote of $4130 for daikin 3 ticks system 4 with upgraded materials. Hope to hear some inputs. Thanks all.
terumo
Is the living room 22k or 18k btu?
Hi gurus
terumo
Then this price is slightly overpriced, if 22k, then its reasonable.
But if their service quality is good, paying a bit more might be good thou.
Living room will be 18k bro terumo.Daikin 3 ticks model.
Outdoor 32k + indoor 9k x 3 + 18k.
Model 4MKS80FSG + FTKS25DVM X 3 + FTKS50FVM
portable aircon creates negative pressure which will suck warm air from outside into your cooling area, it will never be cold and small evaporator and condensing coils plus the hot exhaust hose and compressor all in the room means low efficiency,
portable aircon 7 btu per watt, 8400 btu = 1200 watts per hour.
mitsubishi 5 ticks average 16.6 btu per watt, 8321 btu = 500 watts per hour.
shawplee
Avoid AirCon Installation By Coolserve
Installed a Mitsubishi system 4 (5 ticks & ~$5000) and barely half a year the aircon leaked water. The company service man said the dust causes water leakage and he flushed the water pipes. 1 month later, same unit leak again.
Avoid getting your aircon installed by coolserve
:mad:
GBC
:mad:
Could be that your place is very dusty and you didn't clean your aircon filters.
nakitaro
:mad:
hahaha. typical scam reasoning. ans is, your aircon not installed properly. mind sharing where you purchase ur aircon?
watzup_ken
I think its a little extreme that one month later the amount of dust will cause air conditioner issues. Likely its due to poor installation.
nakitaro
Hi there, I would like to change my 4 aircon unit. Called a guy down to check on my current aircon unit and he said the cost of repair isnt worth it. I'm ready to change the 4 aircon units but he said since the piping runs through my cabinet, they would need to hack it. This is a major problem as he would need to hack 3 cabinets and it would be totally destroyed and the cost of replacing it with 3 new room cabinet isn't cheap either. My question is, is there a way for them to install the new aircon units without hacking away my cabinet? Thank you
lay pipe above, means you need pump. find a pump that's not noisy. the one they provide is crap
