[SIC] Hoot Club! Post Your Technology/Hardware Related Purchases Here! - Part 4
5star_pundit
hand carry this back from m'sia
:s13::s13:
NeonX
Mod it lah, here is mine. Do note that the fans setup is very important. Initially I thought the mod had failed as the temps were just a few degrees lower.
But after adding additional fans, it pretty much stabilized the whole temps for the rig. Currently running 3 intake and 3 exhaust. one of the intake will only activated to run when it hit more than 35 degrees. Running idle on my rig, the temps for the two GPU is just 31 and 32 degrees with 2 intake and 3 exhaust.
If I were to on Air Con at 26 degrees, the temps would be + 2 - 3 degrees max at idle.
but the amount spend modding i probably can get another case leh
Cedesria
If u buy another case. Can u guarantee the temps is worth the effort. I am lazy to switch case that's why I mod
koroshiya8
Koro bro, dmg? Got comparison to varmilo?
Sent from Samsung SM-A520F using GAGT
$173 after using some discount in Lazada... ordered Sun, delivered this evening.
Cant compare with Varmilo cos that is bluetooth and no RGB.
The finishing is much better in the CM while the Vamilo has a rougher feel to it. CM overall has a more premium construction for $20 more compared to Vamilo. it definitely feels CM can last longer in terms of durability.
Typing wise can get used to it quite fast... RGB is pretty standard like how the Corsair software works but not as complex or comprehensive as Corsair.
etoilebiscuit
I want a non rgb and wired one. Like va87m. That's why asking.
koroshiya8
