Samsung Galaxy S8: Huat Ah! Will This "8" Bring Samsung Fortune?
deathst
How do u access Samsung Cloud from the computer? I accidentally deleted some photos and wants to retrieve back from Samsung Cloud. I tried googling but cannot find any solution. Thanks.
Uhh you need a Win 10 PC first cause Samsung Cloud can only be accessed by certain applications made by Samsung.
https://www.microsoft.com/en-gb/store/p/pc-gallery/9nblggh4n9r9#
You can try this Gallery Application, made by Samsung you will need to sign in from there. Hope you can get what you need.
(PS I recommend Sync and Backup with Google Photos, it works everywhere)
Cyno505
Thanks for your quick reply. Tried, but PC Gallery is not currently available on the store. I can see it but cannot download.
deathst
Umm I see. Yes it is region locked application. IF that is the case then there is no other way other than using GALAXY devices in their Gallery application.
gapboy
anyone have problem with backing up on Samsung cloud I keep getting error 405. deleted old backup didn't work only happen recently.
agcken12
whenever refresh gmail, will get Samsung cloud stop working notification.
spiez1
anybody has idea on when is the next price drop for s8+ given note 8 is announced already?
KeYoKe
Same same. No change in battery. I'm rarely hit by odd battery drains coming from a lot of devices. Usually, applications I've downloaded are always more up to date and not some shady photo editing applications, task managers/cleaning applications, package disabler and obvious application designed for very old Android versions. People do not seem to believe that cleaning applications, package disabler and task managers actually will get negative effects eventually.
Im now waiting for the update :s13:
