HP Enterprise MSR930 Router
Mugen
Anyone here using this model for their home broadband?
I bought this thinking it would be an easy setup like any home router but turned out is not. LOL. I guess the Enterprise really meant something. Don't play play. :s13:
I'm no expert in CLI and such so maybe can get fellow HWZ here for help? I'm on M1 1Gbps plan with white Huawei ONT.
I managed to get into the web access with DHCP running and WAN status stated connected but I can't surf the internet. My plan is to use this as a main router and wired switch as well as with 2 POE APs within my home.
pegasus21
Haha... I have a couple of these lying around collecting dust since I use a Cisco based environment.
I decided to power one up and see. Since you managed to get to the Web UI, first follow the basic wizard config steps to set up GigabitEthernet 0/0 as your WAN interface using Auto connect mode for DHCP.
VLAN1 is your intranet subnet. Set whatever subnet you want. Enable DHCP server for your intranet accordingly.
After you apply and save the basic wizard config, add a NAT for GigabitEthernet 0/0 to interface address and your basic router should be usable.
You'll also want to restrict the IPs that can access the management of the router. This is under Advanced, Access sub menu. Probably restrict telnet and web(http) to your intranet subnet.
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03026850-1.pdf
BTW, I've just looked at the specs of the router and I wouldn't recommend this as your home router as it only has 300Kpps throughput (64 bytes) which assuming has the same throughput for 1518 bytes results only about 455MBps throughput. For bidirectional traffic it would be halved. There's no mention of whether the throughput is for bridging or routing and whether NAT/access lists are in place so take that figure with a grain of salt.
I expect it is only good for at most 100Mbps lines since it was given with a 30Mbps line.
KalTorak
Wow! This router I remember Singtel provision for their E-Lite business fibre plan (10M-100M) many years ago.
Hmmm, but I doubt you can fully utilize your M1 1Gbps since the WAN-LAN (routing) performance is only around 200Mbps? I hope you didn't actually buy this router. What PoE APs are you using?
Mugen
BTW, I've just looked at the specs of the router and I wouldn't recommend this as your home router as it only has 300Kpps throughput (64 bytes) which assuming has the same throughput for 1518 bytes results only about 455Mbps throughput. For bidirectional traffic it would be halved. There's no mention of whether the throughput is for bridging or routing and whether NAT/access lists are in place so take that figure with a grain of salt.
Ah, I didn't add the NAT. No wonder. Will try that. Thanks.
Mugen
I bought it quite cheap actually. The reason why is I intend to use it with POE APs which I have not buy any of AP yet. :)
KalTorak
What APs are you looking to get?
If you are getting Ubiquiti UniFi APs can also consider their EdgeRouter PoE (ERPoE-5). I'm using this to power 2x UAP-AC-LR. Confirm can fully utilize 1Gbps fibre plan!
ArcticCheetah
1Gbit/s = 1000Mbit/s = 125Mbytes/s
Assume 1500bytes MTU
125/1500=0.08Mpps
0.08*1000=83Kpps
350Kpps not enough?
Vendor publish specs with low MTU to show the PPS calculation no point showing 1500MTU because defintely higher than physical PHY
KalTorak
125/1500=0.08Mpps
0.08*1000=83Kpps
350Kpps not enough?
Yeah, my bad. Sorry!
TS should try setting up NAT first to see if LAN clients can access to Internet.
pegasus21
125/1500=0.08Mpps
0.08*1000=83Kpps
350Kpps not enough?
The issue is that the spec sheet never stated how the 300kpps is achieved. If it is just bridging, routing or switched without any advanced features like NAT, access list or queues, the figure is going to be on the very optimistic side and not going to reflect real world performance when used as an internet gateway router.
Based on the Image in the earlier post, it looks like it is only good for up to 200Mbps performance.
liangtam
Some sample config w/ NAT for you
interface GigabitEthernet0/0
port link-mode route
nat outbound 2000
ip address dhcp-alloc
interface Vlan-interface1
ip address 192.168.1.1 255.255.255.0
dhcp server apply ip-pool vlan1
dhcp server ip-pool vlan1 extended
network ip range 192.168.1.2 192.168.1.254
network mask 255.255.255.0
gateway-list 192.168.1.1
dns-list 192.168.1.1
acl number 2000
rule 0 permit source 192.168.1.0 0.0.0.255
Mugen
Thanks to all for the support. I managed to get it work by just doing it from the web access. I just do the NAT configuration on GigabitEthernet0/0 with Interface Address and viola!
Speed wise I compared with my Asus AC66U is still slower but in real usage, I don't see any slowness at all. In fact, I felt much more responsive and smooth!
I'm using my old AC66U as an AP mode for now. Will do more research on what POE AP to use. :)
Mugen
nat outbound 2000
acl number 2000
"nat outbound 2000" and "acl number 2000", may I know what is this means?
Is this something that can improve the connection? Thanks
pegasus21
The 2000 only designates an ACL or access list to limit what IP addresses to operate on. In this case which IPs will be NAT.
roidred
IPV6 Configuration MSR 954
Anyone was able to propagate the prefix /64 received from ISP on WAN port to LAN ports ?
I am receiving valid IPV6 on WAN port but not able to use the prefix on LAN ports. Any idea on configuration.
