tec_geek
- Sep 22, 2014
i believe u pre-order online via app/website. when u select pick from the store, did they ask u to select time-slot? or just select pick from store option?
Yes, you would have to select a time slot upon selecting your option as pick up. There’s a prompt for you to select your check in time.
Mine was the 1230-1300 window.
