They are the same as suntech/causeway point shop promo.
You may want to share what item you plan to buy in order for us to advice.
Oh thanks alot. I am considering getting a spare phone within this month.
But not sure which model is good to get actually. I read that OPPO seems Overpriced as compared to Xiaomi in terms of specs vs money
btw may i know is Mi note 2 worth the 300 sgd off at the moment?
Do you need dual sim?
Normally for a spare phone that menat for normal calls and some casual gaming, can consider note 4 3GB + 32GB combo else top up a bit if you need bigger storage for 4GB + 64GB combo, I do see sgd 285 and fullfil party is lazada for 64GB unit.
Else is really meant to sit in the drawer for backup, can consider Redmi 4X.
same as comex promo that time.
Oh ya for the Black 64gb that is fulfilled by lazada is SGD 285 (no free Mi Scale)
While for gold 64gb is SGD 259.99 from Lazada too
https://www.lazada.sg/xiaomi-redmi-...a2o42.010100000000.0.0.n1apHY&sc=IQsB&boost=1
It will be better to get the gold instead right? (oops just see that it is OOS)
basically here is the price
4X 199
Note 4 3GB 259
NOTE 4 4GB 289
If you don't really have budget concern, do consider Note 4. Quite decent hardware @ SD625.
MiMax and Note 2 is actually okay but considering yiu treat the phone as backup purpose, do you really want to fork out that much.
MiMax 2 $399 @ SD 625 but of course with a bigger screen
Note 2 $499 @ SD 821 which is last year flagship chipset
If you really need the so call free gift, the scale os available less than $20 in lazada which fullfil party is mistore.
Do check properly before order as I notice some of it do not mention anything about free gift.
You can consider mi A1 also. It is hot model at the moment.
Sent from Xiaomi REDMI NOTE 3 using GAGT
anyway thanks guys for your help
Decided on a 4gb + 64 gb black note 4 @ 285
there is a gold 3gb + 32gb @ 219 but i am afraid there are some error hence decided to skip it
Thanks again ya
If you wanna get a Redmi Note 4 at $285, might as well get a Mi A1 at $299, albeit export set?
Got myself one. Supports Singapore's LTE bands
hmm i had placed an order already.
where did you get the export set and how long is the warranty?
