[SIC] Hoot Club! Post Your Technology/Hardware Related Purchases Here! - Part 4
raysusan
Haven't posted for a long long time :s13:
Got this today from Dynacore ... Abdul saw me and put the GPU box in front of me ... cannot tahan waited so long for Galax 1080 HOF but no stock so ended up buying this :s22:
https://photos.google.com/share/AF1...?key=SmNOZkx4SGUzYmdiR0UzSWgtcWEwbkszb2ZtZVdR
Thank goodness it doesn't have the Yellow band which would clash with my build.
Will install tomorrow and run some benchmarks ... especially interested with the overclocking potential and temps. :D
Very nice..
hlots123
its tomorrow liao :D:s12:
dawntime
Cedesria
new hoots for my new BTO. going for simple and ease of setup solution from SONOS for my living room sound system.
all were bought separately. Initially had bought only the Playbar for my TV, but added one Play 1 for kitchen as multi room setup. In the end decided to build a 5.1 Sonos setup for movies and my new set of Aktimate Blue for music in the living hall.
harharhar
Whao. Like that how much is total damage?
Cedesria
$1299 X 2 Sonos Sub + Sonos Playbar
$399 X 2 Sonos Play 1 X 2 (one gotten from US so cheaper a tiny bit)
$79 Playbar Mount
$50 Sonos Bridge (Bought from Carousel, BNIB cheap cheap)
$29 Sanus Universal Soundbar Kit (bought as extra in case I want to mount on TV instead of featured wall)
$150 Sanus EFSat Mount for my Play 1s (prefer this smaller footprint to the Play 1 speaker stand)
If want to include my two pairs of Aktimate Blue it would be extra $1499 X 2......
eat grass hoot
harharhar
$79 Playbar Mount
eat grass hoot
wow congrats congrats :D
first step, I need a BTO first :s13:
Guyver
waiting to collect my iPhone x black 256gb today . will stop buying iPhone phones for next 2 years .. cause i bought iPhone 7 plus red earlier this year .. LOL .. i am crazy
Guyver
Retired my old 2tb Hitachi 7200rpm hdd and replaced with 6tb toshiba.
Toshiba brand havent fail me for 3 years running . well done .
raysusan
I never know you are iPhone fan
Guyver
i started with Samsung Ominia then go Apple 3G, 4S , 5 , then Samsung S5 .. after which i went to Xperia Z5 Premium and never go back to android .. from there i switch to iphone 7 plus
raysusan
Any problem upon transfer contacts and back up from Google gmail?
barra90210
Finally finished with Overclocking and Temp tests with the Zotac GTX 1070 Ti AMP+ Edition.
https://i.imgur.com/wpGDQHp.jpg
https://i.imgur.com/t8zx4We.jpg
TLDR :- overclocked it runs slightly faster than a stock GTX 1080 but at quite high cost with higher voltages and temps.
Highest stable overclock I got was GPU 2101MHz Memory 2202MHz with a 3DMark Timespy graphics score (different from the overall score) of 7383 but with temps averaging 78C and getting up to 82C. Voltage averaged 1050mV and hitting 1080mV. I did all the overclocking with the case glass panel removed and ambient temp was about 29C. The settings I used in MSI Afterburner and custom fan curve are below ...
https://i.imgur.com/tWS9I2y.jpg
https://i.imgur.com/neNRF8t.jpg
As a comparison, the out of the box stock Timespy graphics score result was 6852 with temps averaging 72C. So the overclock gave a 7.75% increase in Timespy synthetic performance. As far as gaming performance, in Mass Effect Andromeda, visually speaking everything already looks fantastic on a 1440p Gsync monitor and I really can't tell any difference between stock and overclocked settings as framerates were jumping around between 55-84 fps at 1440p Ultra settings. The only perceivable differences are the temps and voltage numbers.
In MEA, temps went up to 82C on overclocked settings and even at stock settings temps were still a balmy 78C at 29C ambient with the case glass side panel closed. With the panel removed, overclocked temp was better at 80C and stock temp was 76C.
A couple of things to note is that at idle this GPU is really cool at 41C with 29C ambient and the case side panel closed. This is because the fans never stop spinning which was a surprise for me since most new cards have the fans off function at low temps. Also there are 2 lights on the card that you might find annoying if you have OCD. :flash:
https://i.imgur.com/wxZ7MHf.jpg
At the 2 8-pin power sockets there's this very bright but small red LED that I assume indicates good connection and power delivery. Also there's a small RGB LED at the back of the card below the backplate. You can see it in the picture above at the back right corner of the card. This little RGB LED follows whatever colour and whatever light effect you select for the Zotac name. Both LEDs cannot be turned off in Zotac's Firestrike software. If someone knows how to turn these LEDs off please enlighten me. :s22:
In concluding the GTX 1070 Ti is a great bargain if you desire close to GTX 1080 performance and want to save some $$. Currently you can save approx S$100 if you go for a GTX 1070 Ti. So is the Zotac GTX 1070 Ti AMP+ edition a good buy? Well, I have reservations about the cooling performance but the 5-year warranty can't be beat. Unless you plan on selling/changing your GPU/rig in 3 years time then any brand will do. For me I tend to keep my cards around for spare rigs which I pass on to friends or family so having 2 extra years of warranty is preferred. And an AMP+ Edition certainly makes a better buy than the Zotac Mini SKU considering the high temps this card gets in our tropical weather. As for overclocking this card, I've decided to keep it at stock since there's no real benefit for me in all the games I play and I much prefer lower temps/voltages. I will try some gameplay recording and Twitch streaming using OBS with this card next week and see if there're any issue. Meanwhile thanks for reading and cheers! :D
mib500
im planning to buy Zotac amp 1070 mini for my SSF build.. should be ok right?
Guyver
some may not be completely transferred from andriod to apple and vice versa . but now apple has a quick start function to transfer from one iphone to another . very fast . Samsung also has the software to do transfer to same brand phone.
Psycovirus
In concluding the GTX 1070 Ti is a great bargain if you desire close to GTX 1080 performance and want to save some $$. Currently you can save approx S$100 if you go for a GTX 1070 Ti. :D
I don't know if this 1070 Ti is worth the $770 when an EVGA GTX 1080 FTW is at $788.70. I would rather go with a 1080 for faster GDDR 5X
GTX 1070 Ti is such a weird card.
