Samsung Galaxy Note8 Accessories Thread: Let's Go Crazy Over Them
Flanky
we should organise a pasting workshop on a weekend and we all gather and paste together. sure crowd will come see what we doing... with all the blue lights... must think we doing manicure or something. lol
kingsen
Thanks ! So does it means those qoo10 cheap cheap cable but support QC also can? Switching to android because Apple decent cable is really chop carrot price lol.
any cables support QC 2.0 . no need QC3.0
Avoid Aukey's cable, they are having quality issues lately
shichuanhua
ohya forgot to mention need to be compliant with type c standard
Brandless don't buy
kennyboy
Guys any recommendation for note 8 charging cables / powerbank ?
Miniso type-c is cheap and good. Battery wise Xiaomi recent ones are good as well, cheap and good, but must buy from trustworthy sellers.
VacheronLim
Aliexpress has a few more established brands - Choetech, Baseus, Ugreen
Some of their Type C cable listings got a few thousand orders till date, generally positive and seem to work with fast charging - mostly support 2A current
They even have those with USB3.0 for users who also do quite a bit of data/file transfer, the speed difference will come in handy, and these usually support up to 3A current
I used Miniso & Choetech, no issue with fast charge, but Choetech plug seems to be a little tighter when inserting into phone charging port, while Miniso feels a lot closer to the original Samsung one - not as tight, with a more distinct 'click' at the end when you push the plug in all the way
Both serve the purpose I would say, am going to try out Baseus and see if it's any better/worse.
dodongdodong
been using those cheap cables. works well as QC.
treat it as consumables that need to replaced once it loosens up.
