Recommendation: Reliable workshops in JB
BuGGi3
makes sense.
@buggie call or msg them b4 u go. else buy your parts in sg and bring it there.
no worries. most parts are available for my toyota :D
i do bring my own parts if i manage to source it cheap in sg.
AL5509
Just sharing what was told by the mechanic in jb.
The mechanic actually prefer me to bring my own parts as he mentioned that he sometime also dont know the parts from malaysia if it real or fake(well that can be how bad it is?).
Take it with a pinch of salt for these words.
So if I can, I always bring my parts over to ensure it is original.
kongjj
Any money changer around LCH? preferably walking distance near by?
don't wish to exchange too much RM but also concern not enough for the extra repair.
Thanks.
synyster666
Hi all, I'm driving an 09 Kia Cerato Forte. I am due for 120,000km servicing, changing atf, brake fluid, spark plugs etc. Any recommendations for workshops? Thanks in advance. First time planning to head to JB for car servicing.
AL5509
hachi
LCH Brothers, 2nd link nearer or 1st link? Any directions to go there? Thanks.
koolaid
guys anyone have this problem? after 3 alignments done, the car still pulls left slightly. tires were changed last nov. :( tire pressure checked and it was ok, all 4 at 220. could it be tire balancing not done properly? :(
AL5509
1 of the reasons is our roads are not built flat throughout.
Being a topical country with lot of rainfall, our road surface will be lean toward either sides.
koolaid
could be it road. but never had this problem until i changed tires last yr... :(
snipfer
Bushings.
Forgotten what word/part...it's part of the steering.
The problem is quite specific, steering will turn to either left or right but not both sides. Usually is to the left.
I just changed 2-3 months ago at LCH.
Sent from Xiaomi MI MAX 2 using GAGT
koolaid
Bushings.
i changed my control arm bushings too... at lch... any idea how much they charge if i need to check tire balancing? :(
koolaid
i think you can tell them the prob and let them have a check first.
ya I'll need to go back to them. they did the alignment. problem still there. went back and they swap the front tires. still pull left. gotta ask ah yuan to help troubleshoot. :(
