i bought the phone on saturday..today kana dead pixel / screen burn issue
anyone got 1-1 exchange?
it's at the LG service center right?
Yes, the bros here have managed to do 1-for-1 exchange at the LG service center.
Hi temytemy, omelette and lyk13,
Unfortunately, we are unable to provide you with a specific time frame as to when these features will be available.
These features are undergoing testing at the moment.
Stay tuned to our updates when these features are available on the Pixel 2 XL.
Oh yah forgot about eSIM. Hope Singtel can eventually get this supported as well.If you all can talk to the phone manufacturer to make NFC SIM to work with EZlink, then you have my money.
Not having ESIM support, and not having dual SIM functions is something that holds me back from buying the Pixel 2 xl.
Waaah burn in so fast....i bought the phone on saturday..today kana dead pixel / screen burn issue
Can someone tell me how to get pattern unlock?
I been finding it for the longest time.... I don't like pin unlock
Settings>security& location>press screen lock
!!!! either i'm blind or i'm dumb !!!!
thank you!!!
thank you!!!
You don't like the fingerprint unlock?!!!! either i'm blind or i'm dumb !!!!
thank you!!!
You can use custom navigation bar to add a power button on the side to sleep the phone. That's what I did on mine
Got photo proof? LG oled batch must be the shitz...
Where? The navigation bar?
Finally received my TGSP from taobao.
GPGT.
As usual it doesn't cover the curvature area. If u place the TGSP correctly. It's actually inline with the bezel. So there is very minimal rainbow.
I think this is good enuff for me.
Sent from Google PIXEL 2 XL using GAGT
I'm using the same TG from taobao as well. So far so good. Got my Ringke Fusion Clear from there also.
Did you use the liquid to remove white border?
what about the sensitivity? still ok?![]()
