Oneplus 5T
jesp15
which seller pls
Sent from 1+3T using GAGT
either AT house or simder or other seller with base price of 1000 you should be able to use shop and cart coupon. for q10 gift card you can buy 100 x7 with savings of 21. by using your cc you may also get rebate
jtec14
which seller pls
still got xiaomi store and newstar.
Take note last day to use cart coupon today.
rollanddie
What's in the box:
Cell Phone: 1 ,Power Adapter: 1, USB Cable: 1 Back Case : 1, Screen Protector: 1, SIM Needle: 1
I wonder if the adapter and USB Cable is the DASH charging type :s11::s11::s11:
Skyy
1000 q10 12.12 price
- 120 (shop coupon)
- 120 (cart coupon)
- 21 (q10 gift card discount)
- 66 (credit card rebate)
can go as low as 673 for 8G/128MB op5t ;):love:
Credit card rebate $66? Zhun bo? U spend $700 on Qoo10 gift card means the remaining cost to be paid by credit card is only $60. So u charge $60 and get $66 rebate? Wow I'd love to know what credit card u using.
(edit) think I know what u mean, u charged the $700 for the Qoo10 to that credit card that gives u the rebate of $66? Sounds like a new credit card cos normal cards won't give so much rebate just for $700+
jtec14
What's in the box:
first time buying export phone?
The power adaptor and cable should be the originals, came with the phone.
The reseller won't(should not) change any as-is accessories.
You can just buy $1 adaptor to use the china plug for dash charging.
ecneret_eel
yup, found them both, but between these two I think simder is the more established seller right?
hmm the gift cards can buy online and use immediately?
rollanddie
yes first time buying export phone hence many noob questions :D:D in fact, first time buying phone online
used to re-contract from telco
jtec14
simder, gary got some bad reviews for them.
So far got show stock one only AT House.
Gift cards depend on your account, have you bought and kanna manual review before? If no, can try however with the coupon expiring tonight, I won't suggest you to try it coz manual review may drag until tomorrow.
jtec14
wa means must buy another adapter in order to use the dash charging?
doesn't make sense for local shop to sell phone that comes with adapter that cannot be used locally leh
No wonder your earlier post...:s22::s22::s22:
Export phone usually come with whatever plug that country(where it came from) is using. Make no sense for a reseller to find a local plug(if differs) and change for you.
Anyway for those who bought export sets, plug is not a deal breaker.
zoneniac
Lazada clearing oneplus 5 now. $399 only. From past experience, lazada will sell official set one month plus after the release date. I'm guessing only la
rollanddie
WTF $399 for 64gb and $499 for 128gb!
i will be jumping now if i bought the 64gb at $499!
jesp15
u can use cc to purchase gift card (760) then convert all to qmoney. with this purchase you may earn "up to" x amount rebates or cash back interest depending on your bank.
off topic so I stop there. :)
