do your change fuel filter
snipfer
This is one of those myth local workshops loves to con car drivers to change fuel filter at 40k or 80k.
Times are different, nowadays petrol are no longer as dirty(contaminated with dirt) as back in the 80s
Change fuel filter when you overhaul your engine at 200k
Sent from Xiaomi MI MAX 2 using GAGT
nicholascheans
oh is it... Online says every 10 000 miles😂😂 But fuel filter is quite cheap aye
snipfer
oh is it... Online says every 10 000 miles�� But fuel filter is quite cheap aye
The fuel filter is cheap but the labour is tedious. So the charges is not cheap for most cars.
Usually need to dismantle rear seats and do.
There is no specific symptom cos it there is a problem the troubleshooting starts from spark plugs/cylinder area/sensors/engine then fuel line all the way to fuel filter then fuel tank.
market98
Think TS mix up fuel and oil filter.
Oil filter is cheap.
Fuel filter not cheap. Depending on the car model. Labour quite tedious.
Z_Dash
He nv mix up. Fuel filter is at rear passanger seat.
And indeed the filter is affordable but labour can be expensive.
Also heard the first change for fuel filter if workmanship is bad.......can lead to many problems.
I've been on 50% jb oil for past 3yrs nv changed before.
Alphas
Changed mine car fuel filter at 130K, 10 yr mark. Suggest to change at 100K, I dissected the fuel filter assembly, the filter is freaking dirty and it can no longer perform as a filter with the amount of dirt inside. And a clogged fuel filter can make a car sluggish at high rev since the flow rate is reduced.
nicholascheans
yup but my fuel filter is below actually!! I hope lch brothers will be able to do it right
Ivanpaseo
I modern car fuel pump unit there are 2 filters one is fuel filter and other is fuel screen, to access the fuel pump unit is a tedious labour... If you are at the stage need to change fuel filter. Might as well change a new fuel pump, fuel filter and screen...
Sent from Essential Products PH-1 using GAGT
elf108
No diff after changing. So will Not change unless got problem.
blackestvoid
fuel filter at rear passenger seat is it mostly conti cars?
at least for civic it is at engine bay area and easily accessible?
Ivanpaseo
Old car usually in the engine bay.... Now all new car mostly submerged in fuel tank... Ur video is 2000 Civic......
logitech123
few mths ago i'm having random misfiring and rough idling. change my spare injector and change spark plug and even loaded stock map and still having issue
i decide to check my fuel filter and the cardboard filter is clogged, remove the filter and finally it working
recently i decided to renew my coe and now ordering parts for new pump kit and after market filter from deatschwerks.
160k km and only pump shell 98 for my 06 wrx
its relatively easy to DIY and take about 1hr even for a noob mechanic and i advise to change it in a open space with lots of ventilation and a empty fuel tank
Z_Dash
Be very careful as prolonged duration will have petrol intoxication effect........and in car space will be tainted for a few days of petrol smell.
logitech123
that why do in a open space. remove the fuel pump assembly quickly and work on it in other place
pew
Last time drive cl7 change once ...can’t remember the reason already....many years ago.
