Hi. I updated the sketch to show the datapoints in red. Would this be OK?
Also I need switch because I have 5 data points. Is that correct? Or any better alternatives?
I have specifically told the designer to inform the electrician to install the data points in the utility board as well.
Thanks
Note that each data point can cost $100 ~ $150 depend on contractor mark-up cost.
At this stage it is best to provide a layout of your premise and locations of data points.
In this way it will make it clearer for more to provide better advice and any other solutions, if any.
Back to your mapping.
Each data point required 1 lan cable (Cat-6, preferable) with the other end is another data point.
Even 2 data points on 1 faceplate still require 2 data points at the other end.
Master room.
The Router connect to DP is for wireless and set as access point.
From the Router LAN ports to the 2 PC, and not DP so removed the word.
Bedroom 1 & 2 with each DP will be fine.
Living room.
As for the Internet TV box which connect via Router LAN port, i am not sure on this setup.
If there is problem then you may have to use a switch, meaning that the DP connect to Switch to both Router and Internet TV box.
Living room / study area. 5 rooms flat.
It is fine with a DP to switch.
