Xiaomi Mi Max 2 - The new BIG gets even better!
tpmmark
Hi all mi max user, like to ask where is the best place to buy a local set for this? Went to Suntec just now check and saw the retail $399, and another nearby local retailer slighter less. Any advice on better pricing ?
1982-1994
best is to buy a pristine used set so that your losses would be minimized upon selling it.
otherwise, just buy an export set from a reputable shop. xiaomi handsets are fine, at least you won't be so heart pain if you spoiled the phone.
luckily you never bought it at suntec.
1 Samsung note 8 can get 4 sets of max 2.
cheapest iPhone X can get 5 max 2.
try you luck at carousell.
speaking from someone who bought 6 sets of max 1 and 4 sets of max 2.
my ever first xiaomi phone was max 1 and a used set.
LongGe2009
Now note 8 est cheapest $1055 can get, local set mimax 2 cheapest should be $345.
But honestly hard to use mimax 2 as main phone, the size tough to fit my trouser pockets without creating an obvious bulge.
cscs3
Sshd? Heh that’s just a mSata ssd :o
Probably not being able to find in those small capacities (used to be 32gb+/-) last time
Base on the contract, if cannot find replacement part or cannot be repaired. They are suppose to replace with new PC with similar model.
MSATA 32G or 64G has lots of stock anyway.
Intrinion
Senior Moderator
Senior Moderator
Ah. So it’s a work around of the rules! Fixed PC = furfilment of obligations?
tpmmark
Thanks for all the reply and advice. Shall look at Carousell and online if anyone selling 🙂
Lil_d3viLz
Mi Max 2? Go export set $250 la.
Why would one pay 50% extra just for 1 year of warranty?
Obvious bulge in pants might be a good thing.
Nicknamed "Dua Ki" isn't a bad thing compared to "Suay Ki".
:s13::s13::s13:
ZrE0_Cha0s
:s13::s13::s13:
250 quite good price, but its for 64GB right?
Mystech
I have just bought my Mi max 2 from qoo10 - Newstar ,
Xiaomi Mi Max 2/ 6.44 inch display/ 4GB
+64GB/2.0GHz Snapdragon 6...
Color:Black (RARE) / Capacity:4GB+64GB(+S$10)
Safety Mark Approved Plug::Yes(+S$4.90) / Case:Rubber Case Transparent(+S$8.90)/ FREE Tempered Glass:Yes / Warranty:Free 1 Month Store Warranty ,
self collected for $292.80
You could use that as a benchmark to compare
the casing and the plug was optional , the $10 was for the colour black ,gold will be cheaper
Wah. Why almost $50 diff sia
Sent from Travelling with a mad man with a blue box using GAGT
testerjp
I bought my black local set at $32x last sept/oct. Look like never drop much :o
I'mpossible
Hi all, just got my mi max 2.
Now my display is set to sleep at 30sec of inactivity. When I try to choose other time the settings just won't change? Forcing me to click cancel. Any ideas how?
Thanks
ZrE0_Cha0s
Thanks
tried restart or refresh to see if it works?
