Kyubi
- Jun 2, 2002
Ic ok thanks...Singtel said it will release the exact amount closer to 9th Feb..
Aw3 needs to be tethered to singtel plan in order to use the eSIM feature.. you can’t run on m1 and then subscribe to numbershare, it’s is entirely impossible.
this is weird, so what is the built in LTE function for if still need the phone to be near by.
this is a joke
https://www.singtel.com/personal/products-services/mobile/info/applewatch-series3
this? Got more info here.
The setup process for AW3 LTE is through apple watch app, so the iPhone probably need to be using the same number as the Apple watch.![]()
if this is just for one time step up, no issue to put ST on my iphone.. after setup is done, will switch back to M1 for ipHone.
Does this sound feasible?
think u misunderstand the whole concept la.if this is just for one time step up, no issue to put ST on my iphone.. after setup is done, will switch back to M1 for ipHone.
m1 customer like me no choice liao lol!
Cannot even buy the LTE model sia![]()
thanks for the info.Even if it work also quite troublesome leh.
Imagine u friend call ur phone (M1) u never pick up, be it u never bring ur watch or never pick up.
Den they have to call ur watch (ST) to try.
Message if it’s from iCloud still ok.
Normal sms u text a topic halfway and continuing from another device is weird and u can’t create WhatsApp wor.
Perhaps U can consider getting a LTE and change ur service provider,
remain and wait for M1 to launch
or jut get a non LTE and connect to ur phone like some of us did now.
i am already using the LTE version from apple store jap.
I am ok not having e-sim on my AW3 if m1 not releasing. Anyway i also cannot stream spotify from AW3... sigh
Then what as your initial question? Puzzled
why u want to buy ah
02/02 already, still can’t pre-order on Apple online store. Does anyone know what time will pre-order start?
