Car vibrating
Hi all,
My car will vibrate when the car is stationary, engine and aircon on, on drive mode. The vibration came randomly.
But when I switch off the aircon, the vibration went away but could still feel a bit of vibration.
Anyone can advise what could be the problem? Engine mounting, ignition coil etc?
Thanks
HellHunter
Hi,
air con on resulting in vibration could be a dirty idle air control valve. Also have your throttle body cleaned. Check engine oil level, spark plugs, air fliter.
Hi,
Throttle body cleaned, spark plugs and air filter just changed few months back.
snipfer
One of the engine mountings kaputz
Sent from Xiaomi MI MAX 2 using GAGT
market98
Likely aircon compressor, maybe lack of oil.
Lack of oil, the engine idling not so steady.
Fuel timing maybe low.
unclebutcher
Probably engine mount. Not worth changing if less than 1 year to scrap. Does the vibration stop in neutral? If so, quite likely engine mount
Kia7200
wrong. only korean cars r reliable... according to korean car fan bois here... :(
Cannot be, according to those tpyota loyalist, they dont allow other brand to be reliable. If not they kbkp saying the same crap like a broken record le
snipfer
Aiya let them be. Pathetic Under achieved losers in real life usually wants to act like a big **** in internet. Just let them win and achieve some virtual dignity LOL
koolaid
cannot be... only kia and hyundai most reliable in sg jb some say batam... as per all the korean fan bois here... :(
koolaid
ya... i only have crown and gs300 so better shut up... else korean fan bois not happy again... lol... :(
koolaid
agree with most. ts can be a few things. need to troubleshoot from intake to mounting.
ie... stationary and shifting p r n d with a strong jerking, very high chance mounting worn n need replacement.
else try to clean throttle and maf first to see if problem goes away.
best to bring it to a good mech, like lch, and let them troubleshoot. they are pretty good...
Yes sometimes when I shift gear, there is a jerk.
Throttle and maf have been cleaned.
