If those were for the pros.. what are for the pros now?Sony Vegas, Adobe Premiere Pro, Adobe After Effects, Final cut pro & Da Vinci Resolve. These were for pros![]()
Davinci Resolve, best color grading software and work flow now. With the new v14, it now has became a video editing + best color grading software. If you need more fanciful effects, download sapphire ofx plugins. No round trip needed (eg. FCP or PP to Resolve for color grading).
I've switched to Da Vinci Resolve tooand it's free.
imovie but the end result is really rough. will probably try premier pro next but it's so expensive
You can try out Filmora for that purpose. Only $49, pretty easy to use.
can i do like 1 part at 1/4x and another part at 2x together in the same file ?
Slow MO important partser you mean speed up the clip? If yes, then yes. But Resolve can do it better with speed ramping if you want a smoother speed up/down.
speed up talking parts
Resolve huh.... Later go try
Sent from Sony G8142 using GAGT
yes can. If you have experience in other NLE software, resolve should be easy for you to use.
resolve is amazing sia and so zai until i dunno how to use
last time only imovie LOL
is there a online manual?
i cant find things like "Image settings panel" and...
when i use the retime speed curve, how to enter the % value instead of using my mouse to drag ah... this is to ensure consistent speeds is all the parts which i wanna slow down
Yes on their website, forum as well as YouTube. U can choose the % that u want by clicking on the small arrow button when u activated the speed function. I need to see the thing in front of me to be able to tell u step by step...
If u find it difficult,just use the normal slow mo function and split/cut the clip and apply the desire speed %. Just use ease in and out for smoother effect.
