The Galaxy Note 8 (2017 edition)
kopi22
Is there a way for us to downgrade back to Nougat if something goes wrong with the Oreo update? Asking because I was one of those who had trouble connecting to Singtel Wifi and Wireless@SGx hotspots even though the authentication was already set to SIM while on the French Oreo, and the only way I could downgrade back at that time was sending the phone in at Plaza Sing
Was connected to Wireless@SGx at library just now with my updated Note 8. No issue at all. Able to send and receive WhatsApp and messenger.
Sent from 三星 死亡笔记本 8 using GAGT
hellevate
Just updated to Oreo on the XSP CSC. Besides the tutorials that pop up, I notice that some app's icons on the Home Screen have an additional ugly border around it.
The Chrome and Play Store icons for example are now surrounded by a white frame while my WhatsApp icon has a green frame. This is despite having my Icon frames setting set to Icons only.
Oh well..
rav3nrav3s
galaxyuser
Improvement to Audio
Awesome LDAC support finally arrived on my Note8 after updating to Oreo today.
Sound quality definitely has improved quite a fair bit when using LDAC to connect to my Sony Hear On 2 NC.
By the way my handset is on the Starhub CSC code, though I'm using M1 SIM cos I bought the phone off-contract on Carousell.
StationA
deathst
Blueberrytea
hello, anyone experiencing random restarts on their phone specially when idle?
Not me but i noticed my batt lasting longer on sg oreo instead of xef ones...will update again when battery usage patterns are up and running again
Aelinx
Had that issue .. even after clear cache .. i wipe the phone after flashing oreo as the same thing keep happening .. as of now the phone looks gd no restart ..
vinrom
me too. wiped/reset it before the oreo update came up. didnt experience the issue for a few days. then i installed oreo update, then now the issue happens again. definitely not caused by oreo since it happened since before i updated. i don't know if an app is causing it as it only happens when i dont use the phone. tried closing all apps and even ran it on safe mode. still the same.
im planning to bring it to the service center soon but if i could find a fix now, it would be better... :(
renfred89
By any chance have you accidentally activated the auto restart/reboot schedule?
renfred89
if it keeps happening on random timing, and not activated by auto reboot schedule, might need a check on the battery or the system.
Sometimes short circuit of the connection and battery issue can cause a sudden shut down/reboot..
vinrom
the auto reboot is disabled when i checked. okay so i really need to visit the service center for this issue. would you know if SAMSUNG singapore provide a service phone just in case my note 8 needs to be admitted to the hospital?
renfred89
They do provide a loan unit provided, there is available units for loan. They will try to match a loan unit that is equivalent to your note 8 level of features, but no guarantee one.. Also, they will try to fix it within a day if they can, if cannot then they will tell you also.
Also, do check your peripherals like microSD card or sim card. sometimes these 2 got issues, will also cause a reboot.
I suggest you take out your microSD card first if its inserted, sim card spoil is almost impossible to know unless it has no connection with the network..
