They do provide a loan unit provided, there is available units for loan. They will try to match a loan unit that is equivalent to your note 8 level of features, but no guarantee one.. Also, they will try to fix it within a day if they can, if cannot then they will tell you also.
Also, do check your peripherals like microSD card or sim card. sometimes these 2 got issues, will also cause a reboot.
I suggest you take out your microSD card first if its inserted, sim card spoil is almost impossible to know unless it has no connection with the network..
I dont have an SD card. Im using both slots for 2 sim cards. i tried reinserting those also but still got the same issue...
Thanks, good to know that they will provide a service phone as this is my only phone now.
