AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
86technie
Previous generation of AMD Ryzen based laptop like Think E485/E585 was rather popular.
I will update here the newer gen models which are:
Thinkpad E495 (AMD Ryzen) - No review yet
Thinkpad E595 (AMD Ryzen) -
Pros
+very good input devices
+contrast-rich, bright IPS display
+good CPU performance
+fairly quiet
+good SSD
+GPU a lot faster than Intel UHD graphics
+very constant performance without drops
Cons
-only microSD reader
-GPU performance throttled (no dual-channel RAM)
-1x USB 2.0
-weak color-space coverage
Lenovo ThinkPad E595 Laptop Review
Thinkpad T495 (AMD Ryzen Pro) - No review yet
Thinkpad X395 (AMD Ryzen Pro) - No review yet
AMD Ryzen chips are unlike older generation, now most Ryzen APU chips offer well rounder performance for both CPU + GPU.
On par with Intel mobile chips while the integrated Radeon Vega graphics trash Intel UHD easily.
But for gaming discrete graphics will still outperform integrated Radeon graphics since it lack dedicated VRAM.
In SG the above are decent models whether for work, light gaming and etc.
The E series are budget while T and X are premium line.
Take note AMD Ryzen Pro features and cooling are different from
AMD Ryzen consumer.
Which to pick depend on your budget and usage.
Generally E series are decent enough.
Take note for what I know AMD based Thinkpad are sold online, have yet to see any retail shop selling it.
In SG there are other AMD Ryzen based laptop such as:
ASUS X512DA (*Uses HDD not SSD)
ASUS FX550DT Gaming laptop uses AMD H chips
No other models I have seen so far so AMD Ryzen laptop are rather rare.
watzup_ken
Good price. I was playing around with it, and by adding a 1080P IPS monitor +25, and upgrade to 16GB ram +110. All for 925. :)
86technie
Really is hoot now, think later.
U can't get a lappy so cheap that is on par with Intel i5 with geforce mx150 and SSD.
86technie
What's the basic specs for the system?
Processor
AMD Ryzen 5 2500U Processor (6MB Cache, up to 3.60 GHz)
Operating System
Windows 10 Home 64
Display Type
15.6" HD 1366x768 TN AntiGlare
Memory
8GB DDR4 2400MHz SODIMM
Graphics
AMD Radeon Vega 8 Graphics
Hard Drive
None
Warranty
1 Year Depot or Carry-in(Local + International)
Pointing Device
NO Fingerprint Reader, Black Cover
Second Hard Drive
256GB Solid State Drive PCIe OPAL2.0 M.2 2280 (16GT/s)
Battery
3 Cell Li-Polymer Battery 45WH
Wireless
QCA QCNFA435AC with Bluetooth Version 4.1
Take note:
Panel best to go for Full HD
RAM if possible go for Dual Channel not single
HDD wise up to you but try not to get only HDD.
Windows 10 can run really slow on HDD.
s7460597
Upgrade to full hd is $25.
Upgrade to 12gb team is $50
To 16gb is $110
There's the 1 cents upgrade also.
Can't figure out whether can upgrade to Ryzen 7 to find out the cost.
86technie
To 16gb is $110
At the moment don't see option for Ryzen 7.
ZrE0_Cha0s
seems like the basic specs like really not bad though. just that not sure how is the temp of the system. although 1.75kg seems like quite okay weight (not too heavy and light though)
Phen8210
better look at the interior design before purchasing
s7460597
It's aimed at sme business users. For productivity functions, great should be that much of a issue? Thought concern is more for gaming.
Audiology93
Models
WE'RE SORRY, BUT THERE ARE NO MODELS AVAILABLE AT THIS TIME
How did u guys try and configure the laptop :s13:
Sent from HUAWEI MATE 10 using GAGT
86technie
Models
Oh sux, maybe they forget to inflate the price. :s22:
They take down first than later maybe price adjust above $1k. :(
ralliart_ray
Can what
pawn_king
vega 8 < mx150 right? seems like 10-20% difference
sure it's 1.75kg in 15.6"? hard to beat this weight/screen ratio
