amazingone
- Jan 14, 2015
Mi Max 3 specs?
The Pro probably never existed at all..Maybe no pro version gets the SD636 at $300+ perhaps, but pro ver might pack SD710 selling at $400+?
Possible, just like no Max 2 Pro. It could be just rumor.The Pro probably never existed at all..![]()
The Mi Max 3 will be using the same IMX363 sensor as the Mi MIX 2S, quality should be good unless Xiaomi screw up the software algorithm..Using redmi note series specs and give u bigger screen and battery likely they will compromise the camera.. Then charged higher also..
Wouldn't be surprised given how Oppo is still selling the R15 Pro for $849(RRP)I propose xiaomi price it at $800 with snapdragon 710! Most of the people here sure can afford one..
If it is SD636.....Well....WTF..![]()
you still buy.![]()
Actually, my main consideration is the improved camera... Not so much about the SD#...
The Mi Max 3 will be using the same IMX363 sensor as the Mi MIX 2S, quality should be good unless Xiaomi screw up the software algorithm..![]()
max 3
Redmi Note 5 uses the Samsung S5K2L7 as its main camera, which powers the Dual Pixel technology for fast AF. Secondary camera is the Samsung S5K5E8, used for blurring effect in portrait mode.Hey Amazingone, is Redmi Note 5 AI also using IMX363 senor?
I have switched form Max 2 to RN5 AI recently because of the better camera but not use to the smaller screen. I am thinking of getting Max 3 when it is launched.
Just wondering is Max 3 camera on par with RN5 AI.
