- Apr 8, 2011
Unifi controller, just took it off AWS about a month back.what other VMs you run on it since it only has a dual core cpu?
I have both the unifi controller and pfsense VM connected to the same LAN vSwitch which is attached to a single physical interface, didn't notice any slow downs with the OpenVPN server that's being run on the pfsense VM.Does sharing pfsense network interface with a VM cause any slowdown? I had a VM and proxmox run on the same LAN port before and any network activity causes to CPU usage to go up and vpn server is slow to respond. Moving the VM to its dedicated network interface solved both issue.
Since the UniFi Controller isn't going to generate a lot of traffic, I've went ahead and spun up a windows VM; ran a few speed tests on the windows VM and everything still runs smooth, no noticeable slow down even when connected through the VPN server.
Oh, and all the VMs are using vmx3net virtual NICs with Directpath I/O enabled.
Maybe is due to the built in realtek NIC. Or I may have set my network device as intel e1000. My issue is openVPN responsiveness. Running an iperf test shows no issue. Switching to a dedicated NIC fix that weirdness.
Adding the USG Pro to my own setup. I had requested Viewqwest to put my zhone into bridge mode (I asked them to disable dhcp and switch to bridge mode but for some reason it's stuck in bridge mode with DHCP enabled) but somehow can't get it to work.
Could I trouble you for your zhone modem settings?
Changed to a single 16 port switch to avoid all the interswitch links and also moved all of the equipment into a proper server rack. A lot more quieter and infinitely neater..
Finally got both of my access points mounted to the ceiling to improve the coverage cone. One for each floor of the house.
Want to check - I am also planning to change to a full Ubiquiti set up and I am on Viewqwest (1 GBPS plan)
USG (still thinking either USG or USG pro 4)
US-16-150W
Cloud Key
2 UAP (still deciding between Pro and nano HD)
My current set up is zhone modem (bridge mode) connected to a asus ac-68u (router). Do I need to call up Viewqwest to inform them I need to change router and to provide with the new router information? I remembered the technician telling me something along that line.
Anybody know whats the best way to reset cloud key without losing my settings?
US-16-150W
Cloud Key
what power strip or PDU are you using?
Oh my, you mentioned you only had 1 AC-pro though.
I see that you have a false ceiling . Why not run the wiring through that instead of using the casing?
I have 1 AP in each room. All bedrooms uses the UAP-AC-IW . Living room has 2 UAP-AC-LR, one at each end of the house.
I like to flood the house with 5G. 5G has very poor wall penetration, hence need 1 AP per room
No longer needed to call into Viewqwest for a router change.
Get the Nano-HD if you have the budget, more future-proof.
how is the noise of the
1. US-16-150W
2. USG pro 4
I read many other websites/forums
1. US-16-150W is ok, quite quiet
2. USG pro 4 is very noisy and they had to change the fan.
Is this true?
