Volvo Review - Most unrealiable & most problematic car I ever owned
trento
Of cos u r entitled to disagree. But it’s a fact the gearbox parts have this lifespan. Even for torque converter auto, the gearbox last about 150k.
Perhaps u should have research into s60 more thoroughly before buying.
I tend to disagree that gearbox has to be changed in this type of timeframe.
Ghost777
Speaking as a Volvo owner, a S60 T4, the car has been extremely unreliable. Nightmare driving it. Fully maintained by sole agent but yet all the following failures.
My car in the 4th year, had a major engine breakdown & needed replacement. Before that, there were cases of engine oil leaks, changes of gaskets etc.
After the engine was replaced, immediately, the clutch totally failed and needed total replacement.
And shortly after, the gearbox failed and needed total replacement, all within a short 1.5 years!
Basically, I went back to sole agent around 10 times and the longest that I have to leave the car there is around One to one and half months.
It was a nightmare, totally painful.
My patience has finally run out.
That is why diesel car cannot be trusted. Problem comes.. very headaches.
trento
Diesel and petrol gearbox same model?
volvo dual clutch gearbox is made by Getrag. not sure diesel and petrol same gearbox but petrol confirm is dual clutch.
like vw, volvo does not make the gearbox. the dry clutch (which i think is fitted on the s60) has a higher wear rate compared to a wet clutch.
Athany
Diesel D2 model uses ford engine. I doubt diesel and petrol uses same GB. Diesel rpm lower, doesn't use high rpm to archive max HP. Anyone can confirm?
sinicker
S60 D2 driver here, into my 4th year currently. no major problems thus far, i am aware of the diesel battery problem. Of course the resale value bites, so i will wait until the right time to sell.
COE 78K here :(
That is very high COE bro... Myself 66k COE to 34k COE I'm so glad I've changed.
mel1888
Yea i got shite 75k COE too. Glad I have changed hopefully to 32 COE.
TS i think ur maybe one of the few thats hit with so much issues. Lemonic car.
trento
tats the engine side. the dual clutch dry gearbox is a known high wear rate item. of cos, ppl tend to mistake that as a problem but it's actually wear and tear.
trento
guess so. very rarely see diesels use dual clutch gearbox
TopGun
Gearbox failure at such mileage is certainly not usual. The last it happened to VW, warranties had to be extended.
trento
The dry clutches typically last 80-100k. Also our city traffic shortens the lifespan.
Mechatronic units around 100k. Extend warranty doesn’t mean it’s not normal. Simply means AD do out of goodwill.
Dolphin
If that’s true, who in the right mind will buy such cars, every 80-100k to spend $6000 (full price) for a clutch and $13000 (full price) for a gearbox due to “wear and tear”? It’s madness. For the past 20+ years, I only have to change oil for my other cars & nothing else, & some surpasses these numbers at 150,000km mileage.
trento
Ppl who like the drive and don’t mind the cost, or at least r aware of it.
The clutches cost about 2k. Mechatronic unit about 3k.
The past 20 years i assume u had a different type of gearbox
Dolphin
Hmmm. You sound like some workshop promoting repairs :)
