just got mine set up
USG-PRO-4
US-16-150W
UAP-AC-PRO
UC-CK
Mounted on a 6U Startech wall mount, bought a 1U PDU (UK PLUG), hid it inside a small closet which used to house my AC68U router.
For those using viewqwest, when you switch to the new USG, please call their technical hotline 3102 0000 and inform them you are switching to a new networking device. They will check from their end and "clear" the old MAC ID from their system.
Upgraded both switch and AP but the USG i just leave it as it is because I want to monitor if there are any random reboots. My USG was tested in April 2018. Not sure if the problem was fixed by then. I also changed to 2 Noctua fans. Tried the original fans and it was ridiculously loud. The Noctua fans are very silent but my hardware are running hot. Monitoring for a few days first before buying a small USB fan to cool it.
Also saving up to buy a rackmount NAS (still thinking about it though) but for now the internet is temporarily settled till the inch starts again.
