Samsung Galaxy Note 9: Will This Be A Game Changer For Samsung?
Habrosus
When you set the watapps chat group to mute, at the timeframe to mute page, uncheck the show notification box if you only want that particular chat group not to show.
At the Whatsapp settings where you chose to mute notifications, there's a tick box down the bottom for you to choose if you want to show notifications...? :)
joeey
Under the wifi status, restrict network data, there is this auto, metered and non metered.
Previously android i use, the restrict network option isnt like this.
what you mean?
Sent from Samsung Not 9 ? using GAGT
rachdanon
Did you uncheck "show notification" ?
Yes uncheched that in whatsapp. As someone above also posted there is a whole list of apps under Notification settings of the Note 9. Will uncheck whatsapp and see if it stops.
elmariachi
Anyone knows how to change the CSC code for Note 9 to XSP?
I tried it but it comes to another menu where is says something like network sales code and some other option? Anyone can help?
Thanks!
ttytwe
Issue: Even though whatsapp chat group is muted, screen still lights up and it is shown on the lock screen when messages come in.
Any advice how to prevent that?
go whatapps > settings > notification > group notifications> popup notification> choose no popup
there is 4 settings under popup notification. No popup or Only when screen "on" or Only when "screen off" or always show popup
deathst
athenodorus
Do u all have this issue where u took the phone out from pocket while fingers on the screen n the screen wakes up ?
Also is there a button for u to toggle sim 1 or 2 data?
Can't seems to find ....
Turn on the prevent accidental touch?
Habrosus
I think disabling notification via an individual group chat vs the Settings>App>Whatsapp method, the latter will affect all other chats that you actually want to be notified of...
deathst
Red_Cheesepie
Yeah I have the same issues with my pixel 2 as well so I decided to make the switch. I have been using only stock Android previously as well. If I really can't stand the TouchWiz, will consider switching back the the pixel in the future
Sent from Samsung SM-N960F using GAGT
Couldn't make up my mind yet.. so loving this note 9 or still prefer pixel 2 XL?
bestbargainltd
All new Samsung Galaxy Note 9 in all available colours
The best phone that money – a lot of money – can buy Bigger than previous Note phones in every way, has a larger 6.4-inch screen, heftier 4,000mAh battery, and a massive 1TB of storage option. The biggest Android phone that will grab your attention in 2018,
Comes with:
New Samsung Galaxy Note 9 6.4 Inch Dual SIM SM-N960 218GB / 512GB Factory Unlocked Phone
Samsung 12 Months Warranty
Original Samsung USB Charger
Original Samsung USB Cable
Original Samsung Headset
Original Samsung Phone Case
Original Samsung SIM Ejector Tool
Original Samsung Micro-USB to USB Type-C Adapter
User Manual
512GB PRICE: S$1350
wait no further come get yours NOW! Whatsapp +65-83629788
NOTE: A lot of customers contacting me please be informed this is a brand new phone still sealed in box never opened and not re-contracted phone this is the best price for a sealed Note 9 and comes with local warranty only few left hurry guys..
SERIOUS BUYERS ONLY!!
ttytwe
for my group notification, i didn't use the mute setting. i put the notification tone as silent. so it wont vibrate or sounds. its like forever in mute till change it. but i set led color that blink on the left top of my phone so i know i got incoming msg on my group chat
That will completely disable notifications as a whole.
You will need to mute per group individually, like in this screenshot
Ensure popup notifications is not turned on and try a reboot.
renfred89
Like what deathst has mentioned, no real life advantage of changing.
If u die die wanna change, *#272*IMEI#.
Phone wipes to factory default afterwards.
Thanks!
