windwaver
- Apr 28, 2000
I seldom buy on Qoo10 so I don't have gift card or rebates
Just that 8% cart coupon only.
Sianzzzz.
But ok la better than nothing!
Aiya, you got the last blue
Sianzzzz.
next time purchase high amount item go inside to buy giftcard $100 at $98 then top up the giftcard into yr own account to use...
But after thinking lucky i bought black cause the free case is slight black color it wun turn yellowish like clear type.. Xiaomi default case is quite good so i look forward to it.. never order case... just order 2 x 5D full glue tempered glass..![]()
Aiya, you got the last blue![]()
Hey bro, I looking to buy protector and flip case but can't find any. Where you bought it from?
Aiya wasted.
But nvm la. An upgrade from my almost 3 years old redmi note 3. Should be worth it.
Mi Premium Store in Qoo10 is the official store too?
Sho means Xiaomi whack tons of SD845 cpu units in good wholesale pricing?
May I ask what is coupon code to apply? It said I have no coupon. Thanks.Apply the coupon when you check out; discounted price will show up.
great u can taihan the note 5 AI... this is a great phone too... but this pocophone is even better.. $400 vs $270![]()
go to the link the bro posted and grab the 8% coupon... it should show up inside qoo.. then buy giftcard to top up.. hurry i think black set left 2 sets too.. else u need to get from JTBC they said is local set also..
If we compare it to the Note 5 6GB variant .. price would be even closer ..
wonder should i downgrade fcrom my vivo nex s
u got use to OLED panel u will find IPS shitty...wasted can minus additional $8 off.. bring to $405 before CC rebate
Shopback can give $4.49 (1%) more rebate. It will include the gift cards portion you use. So before CC rebate, it's $400.51.
If you go JB .. need to grab lah, take bus lah, spend money on petrol lah (depending on your transport). And .. without warranty. And SST will be included real soon.
