Xiaomi Pocophone F1
PiGuDong
I topped up 40 also.
But I think they know Shopee has less vouchers than Qoo10 hence got difference.
Anyway no regrets topping up. :) I feel that extra 64GB will pay off as I intend to use the phone for the next 2-3 years.
Can buy 128gb microsd card with $40! :(
Nakedtoes
Qoo10 I brought it down to paying about $405 (gift cards + 8%), after topup it became $445.
Shopee if you bring it down to $424 (no idea how you bring it down) , after topup will become $444....
Verdict:
- If buy 64gb, its about $19 cheaper in Qoo10
- If buying 128gb, shopee is cheaper by $1
Yea.. Tml only blue color.. If got black likely I will top up
windwaver
Verdict:
Wah, can bring down to $424 :eek:
MrRayded
Any word on whether the red colour pocophone F1 coming to SG officially? I really want that colour hahahah
FinalTidus
Speed is faster on internal storage. Apps, photos, videos taken by the camera will be stored here.
For microsd card I use for importing 1080p or 4k movies and music. :)
Nakedtoes
Video and photo can store at sd card..
Nakedtoes
Verdict:
Can bring down even lower.. But I can't find mi prenium store in shopee..
FinalTidus
Can also but my movies and music can already take up 100+GB already.
So I usually use my sd card exclusively for movies and music.
Internal storage purely for apps, games, photos and videos which surprisingly nowadays can take up so much space :(
Nakedtoes
If blue set give grey tpu case I dun mind.. Hiaz.. Maybe will do carbon fibre skin on phone then look like amourer version
Mystech
Both are quite different phones. Feel both.. Max 3 can be super Hugh for those who nv use max series phone before.. I used max 1 before so I can get use to it very fast.
Agree. Using note 4 now, and bro using mi max 2, so tried before, not much issue. As I mainly use for work, so not much need for a higher chipset. Looking more at value on my side
Sent from Travelling with a mad man with a blue box using GAGT
KalTorak
Yes there is throttling on the SD845. That's why they have liquid cooling on the Poco F1 for better thermal management. Antutu scores and gaming fps dips when the SoC overheats.
If you had watched the Poco F1 Indonesia launch last Monday, you would have seen the Pocophone maintaining the Antutu benchmark scores even after the 6th run or cycle. Whereas other similar SD845 flagship phone's Antutu scores took a dive after the 5th run, due to thermal throttling kicking in quickly.
