Viewqwest security issue and horrible service
zeroex
18th Sep midnight:
Went home to find internet not working. My Asus router was fine, check the WAN ip and found that i was assigned a internal ip address (192.168.1.10) from the ISP.
it seems that I am connected to a internal subnet, could be another vq customer's. Map the network and found a few pc and phones connected.
The router apparently is a netgear router (i think its provided/configured by VQ?) and guess what? Default admin/password credentials. I was able to login, just to take screen shots. (will post ss later as pic not with me)
Called tech support, a pinoy sounding staff (Joshua) took the call and i explain the problem. He doesnt know what i am talking about. he only offered to reconfigure my ONT modem to get back the ISP static ip.
I explain this is a serious security incident, that they actually link or misconfigure customer's subnet together, using default password.
He say he is junior staff, so I ask for senior staff or mgr, he say no one in the office. Their 24hr NOC has only 2 staff, with no mgr or security incident management plan.
He dont know who did it (no audit trail of their staff configuring customer device, hence any staff can potentially misconfigure customer device and gain entry into their private network) LUCKY i am using my OWN ROUTER , if i am using their router or setup I would be exposed to dunno how many people.
He offered to get a mgr to call me back. I ask him if there are any customer who encountered this issue, he say dont know, if got wait for them to call techsupport. (facepalm)
19th Sep
Noon: No response or call back from VQ.
3pm: VQ support called but I was unable to pick up.
430pm: VQ tech sp eng (Shift lead) called back.
His explanation:
There was an unannounced maintenance going on by Zhone (the company).
Zhone had pushed out firmware upgrades to fix some network spd and connectivity problems experienced by other VQ users, and apparently VQ had no control over that.
Some of the firmware upgrade result in the modem booting into a default state, which ended up in the internal ip. (meaning to say a number of users could potentially have all end up in the same subnet)
He was trying to gather more info from me, and i explain the situation (above) to him nicely. I ask him HOW is this report going to be made known to mgt, (esp since they have network security business, and isnt this a big ***** breach?) At this pt, it is still a "helpdesk ticket", not a "security incident" that is escalated to any manager yet. (i dont blame him, it is VQ protocl/procedure, so he just following by the book) he told me he will monitor my connection, and at the same time, run tru the other customer's config to see if similar situation pop up (which obviously have, if not i wont be able to access rite?)
Can you imagine if this is corporate networks? Esp if they running private lines or mpls where its suppose to be isolated?
I dunno about u, but really wtf siah.
Additional info:
he said VQ only has 2 shift. (8am-4pm, 4pm-1am)
Maybe anything between 1am-8am is for the poor hapless tech support intern with a instruction manual. LOL
DriftKing
18th Sep midnight:
Do you mind sharing how to access and check this? Not technical enough to understand.
zeroex
Login to your router, then check the WAN address.
Usually address is 192.168.1.1
zeroex
The WAN IP is not that, should i be worried? (that 192.168.1.1 is to log to my asus router)..
Yes i mean that is to login to your router.
As long as your wan address is the static one provided by VQ then should be ok.
As long as its not in the range below:
RFC1918 name IP address range host id size
24-bit block 10.0.0.0 – 10.255.255.255 24 bits
20-bit block 172.16.0.0 – 172.31.255.255 20 bits
16-bit block 192.168.0.0 – 192.168.255.255 16 bits
Also, if u are using any of VQ provided equipment, pls change the password, since they may use "password" as the password.
zeroex
squarepipe
Now I don't think Singtel is the worst ISP. singTel is just evil, viewquest on the other hand is incompetent...
SibehHL
Why is an ISP that is so bad even allowed to operate?
Is there some gov agency that this incident should be reported to?
fudgie
wow. this is new.
this is a very big security lapse.
but i've never heard of firmware causing such things though? possible?
LiLAsN
Do you remember your WAN IP? All VQ IPs are static meaning a simple configuration on your router side will fix the issue.
I called Viewqwest to set my Zhone Modem in Bridged mode and let my router do all the routing.
Once you are in Bridged mode, you can use your router to configure your WAN connection. It's not that hard. Just go to Settings, WAN IP, and set up the following.
Mine was set to "Get Internet IP Address Dynamically from ISP" by default and it is accurate.
Use Static IP Address
IP Address: 202. **. **. ** (Your static IP address)
IP Subnet Mask: 255. 255. 255. 0
Gateway IP Address: 202. **. **. 1 (VQ's main IP address)
Domain Name Server (DNS) Address
Get Automatically from ISP (mine was checked and accurate once again)
Use These DNS Servers
Primary DNS: 202. 73. 51. 98 (VQ Main DNS)
Secondary DNS: 202. 73. 51. 99 ((VQ Secondary DNS)
Third DNS: 8. 8. 8. 8 (Google's DNS)
For me personally, I changed my DNS to 1.1.1.1 and secondary as 1.0.0.1 along with the third being VQ's main DNS.
All Singapore restricted websites will then be unlocked; even prawnhub. No need for VPN after that. :s13:
zeroex
I know what is my ip, but that is not the point.
zeroex
Update:
I guess i didnt take enuf screenshots. Missed out the main router page which would have shown the other person's WAN address.
My router's WAN ip at that time
I pinged and found serveral devices, and went into the main router. 192.168.1.1 as u can see in the image
List of devices attached to the router.
You know what will be funny?
It may turns out that Viewqwest is using a cheapo netgear router to run DHCP of their customers IP. LOL
You know what will be less funny?
It may turn out that their testing environment is their production environment.
